Game optimizer release for Windows plus obscure CPU setting
Re: Game optimizer release for Windows plus obscure CPU setting
Thank you for replying but I found "cs2" mentioned only twice in the ini file, replaced the first one under Games with "Apex Legends", the 2nd one with r5apex_dx12.exe and still game isn't detected...
Edit: 3rd cs2 found and replaced with Apex Legends as well and still not working
You need to get the exact game name right, so in this example:
[Games]
# Process names without .exe that trigger game mode
r5apex_dx12
[r5apex_dx12]
module=r5apex_dx12.exe*, [auto], pcore, disableboost, applyonce
threaddesc=GameThread*, [auto], pcore, applyonce
threaddesc=RenderThread, (auto), pcore
Or probably the easiest method: open the .ini, Ctrl+H, search for cs2 and replace all with r5apex_dx12
Thanks I think it's working now since I see the task bar goneHyote wrote: ↑12 Jan 2026, 17:01You need to get the exact game name right, so in this example:
[Games]
r5apex_dx12
[r5apex_dx12]
DangerAhead710
I did everything but my screen is flashing after opening the game it turns black and then normal desktop and keeps cycling like this back and forth . My task bar is not visible and I used it for valorant
This happened to me a few times with Dying Light. Try running the program first then open the game or vice versa. Also try switching between FSO/FSE. I don't play Valorant so it's a testing area now.DangerAhead710 wrote: ↑13 Jan 2026, 00:57I did everything but my screen is flashing after opening the game it turns black and then normal desktop and keeps cycling like this back and forth . My task bar is not visible and I used it for valorant
DangerAhead710
How do I revert the changes it has made to my pc?
Sometimes I wonder if people are just trolling with the most stupid questions imaginable. If you aren't then close the program and restart your PC. It doesn't make lasting changes.
Best Gamer Optimizer ! Input Lag is 0 now ! Thanks Bro !
Here Proof me playing and testing it !
DangerAhead710
It did make lasting change and that's why I asked this question. My fps reduced around 50 fps.
The risk of running a exe someone on a forum posted -not saying it is bad, but I would never run a random exe as admin on my PC just saying..DangerAhead710 wrote: ↑13 Jan 2026, 07:51It did make lasting change and that's why I asked this question. My fps reduced around 50 fps.
