Can you record a video playing Battlefield 4?donger wrote: ↑30 Sep 2025, 08:58If you want your inputlag to be like on the video, read on:
Here are some scoreboards, the main point my skill is always the ceiling not how my hardware behaves:
https://imgur.com/a/CztmGzD
Seeing the amount of problems people are having with floaty mouse/lag i've decided to share my RIG which literally has ZERO issues. Forget the bulllshit seen on this forum from some schizos that wrong mousepad or less than 1000W PSU will cause inputlag lmao!!! I never have any lag, my mouse is snappy as fuck, the fps is so high and the frametimes are so low and consistent that you feel one with the machine/game. You can kill people like crazy with zero effort. Just copy my build 1:1 and you can start clapping people. As for the desync i am quite sure most of you just have shitty ISP and there is nothing that can be done about that unless you are willing to change your ISP which uses a different hardware endpoints. Anyways if you follow my guide in a creating a lag free PC and you still have problems then you have narrowed down that the ISP is the only problem.
[HARDWARE]
-Asrock b550 Pro4 UEFI ver. 3.40 Realtek RTL8111H eth controller
-5800x3d undervolted using negative offset in bios -30 all cores
-2x8 Patriot Viper Steel 4400MHz CL19 (ofc you have to set it to CL14/3600Mhz/1800 infinity fabric, or higher depending on the silicone lottery, my setting are attached)
-I've tested 5070Ti and 9070XT both were amazing.
-Corsair RM850x - ATX 3.1 - PCIe 5.1(keep in mind that the included 12V-2x6 connector is of a horrible quality and it's probably better to buy NZXT C850 Gold ATX 3.1)
-Archer AX53 1.5.4 fw.
-240hz monitor Acer Nitro XV272Xbmiiprx IPS (do not get an OLED if you play vision based shooters like Hunt Showdown, the blacks are so good you will have trouble seeing enemies in dark places)
[PERIPHERIALS]
-get a wireless mouse with either PIXART PAW 3395 or PAW 3950 which is popular and known to cause no problems. I have a MCHOSE G3 Realtek MCU ULTRA 8K receiver(more on pooling later)
-keyboard literally doesn't matter i was clapping people on 10$ office dell keyboard but if you really need to know i use Genesis Thor 404 TKL Kailh Brown)
-mousepad doesn't matter, personal prefference, i used Genesis Carbon and using SMX Speed Mouse Mat L Black which literally was 5$.
[WINDOWS AND SOFTWARE]
-do NOT install stock windows, it's literally one huge pile of spy and bloatware. Install a modded windows which is just barebones. I personally use W11 24h2 Ghost Spectre Superlite SE no Defender and having zero issues. If for some reason you don't wanna use it, do your own research and use something else. Do not use piece of shit stock windows.
-after installing fresh windows DO NOT install anything other than:
1.https://github.com/abbodi1406/vcredist
2.directX web installer update https://www.microsoft.com/en-us/downloa ... aspx?id=35
3.chipset drivers
4.GPU driver either minimal installation if you plan on gaming only or full install if you want to set recording shadow play/instant replay.
That's it!! Do not install any other bullshit like MSI afterburned which is known to cause stuttering for some people/games. Go install and play the game.
[MISC]
-do not use less than ~1500 DPI. It increases input lag for no reason. https://youtu.be/6AoRfv9W110?t=303
-do not crank up the pooling HZ to 8k barely any game supports that causing stuttering and your CPU usage will spike. Stay on 2K like i do and 4K only on games which you will test to cause no problems. 8K is snake oil and i have not found a single game working well with it.
-You do not have to spend hours in the registry changing god knows what, same goes for UEFI. This forum is filled with false promise clueless schizophrenics sharing the most placebo BS ever with ZERO proof.
-Always limit your fps, preferably to a number which will not leave you in a GPU bound situation, being in a constant GPU bottleneck will introduce additional inputlag #2. Ideally you should aim for stable fps twice as much as your refresh rate #1.
source#1 https://www.youtube.com/watch?v=hjWSRTYV8e0
source#2 https://www.youtube.com/watch?v=Fj-wZ_KGcsg
This is my first writeup, probably will modify it a bit later on. If you have some additional questions hit me up on discord "slick_dad" or comment here. Also please do not ask me about AM5 hardware simply because i don't have it yet and i do not know which ones will be lag free.I'll probably aim for a MOBO with Realtek eth controller not an intel one. I'll upgrade once the ryzen 10XXX will come out and let you know. Peace.
2025 Anti lag guide in getting new PC and hardware [video proof]
- Yagami
Re: 2025 Anti lag guide in getting new PC and hardware [video proof and no schizo BS]
donger
- Slender
Re: 2025 Anti lag guide in getting new PC and hardware [video proof]
guy without issue write dont have the issue
MegaMelmek
Exactly, he know nothing but he is trying tell us what we are have to do.
There is 0 chance that any PC will work at my apartment with 0 difference if thats online or offline.
I do not reply that often but as Khabib said: This is n1 BS.
Sygey3
Greetings to the author of this post! I wanted to try buying the same components as you and see if the input lag goes away (I'll probably have to buy these components used). What graphics card do you have: a 9070xt or a 5070ti? What power supply do you have: a Corsair or an MSI? What cooling system do you have: an air cooler (what brand and what RPMs does it run at?) or liquid cooling? What SSD do you have? Could you provide screenshots of your BIOS settings, especially the CPU and memory voltage, and PBO?!
My story goes like this: over the past two years, I've changed several computers: I had two 7800x3D system units (one CPU: Malaysian-built, the other Chinese-built), then a Ryzen 5 7500f. Then I sold them and bought a 12700kf, an MSI Edge Wi-Fi DDR4, and a Samsung B-die CL14. And this DDR4 system unit performs better than those computers with DDR5 memory. My personal opinion is that the input lag issue stems from hardware compatibility and proper memory timing and voltage settings!
- naporitan
This is a good topic, and the author is great, but I can't find an official link to the Ghost Spectre iso
donger
donger
Sygey3 wrote: ↑18 Jan 2026, 12:16Greetings to the author of this post! I wanted to try buying the same components as you and see if the input lag goes away (I'll probably have to buy these components used). What graphics card do you have: a 9070xt or a 5070ti? What power supply do you have: a Corsair or an MSI? What cooling system do you have: an air cooler (what brand and what RPMs does it run at?) or liquid cooling? What SSD do you have? Could you provide screenshots of your BIOS settings, especially the CPU and memory voltage, and PBO?!
I have the cheapest 5070ti Gigabyte SFF, i have also tested 9070XT and there was no difference other than amd pulling like 100W more and having quite horrible settings panel. I stayed with NV because i like my PC pulling only around ~250W when gaming.
I have Corsair RM850x ATX 3.1 - PCIe 5.1 Gold
Phantom Spirit 120 cooling, RPMs 0 - ~750
1TB SN850 WD
I have everything on auto, just curve optimizer -30 all cores, all else including PBO is set to auto. I have tested pretty much every single setting in my bios and nothing really affects the input lag in any perceivable way.
I have AM5 build with 9800x3d on the way, still testing and recording stuff that's why i can't really provide any screenshots rn because my old parts are outside my PC.
donger
Then change your apartment, why do you even come here crying if "There is 0 chance that any PC will work at my apartment"MegaMelmek wrote: ↑03 Dec 2025, 05:00Exactly, he know nothing but he is trying tell us what we are have to do.
donger
AM5 2026 build coming soon with new lagmovie
