Nice to join this awesome community
I have amd 7 7800x3d , gpu 4070 super , ram 6000 with EXPO enable , monitor benq xl2540 240 hertz
What should i use in cs2?
Some ppl say gsync,vsync,reflex
other noreflex
other no vsync,sync
Thanks in advance!!
The answer to your question requires a few sub-questions:hurryupabit wrote: ↑10 Nov 2025, 11:52Hello everyone!!
other noreflex
other no vsync,sync
Thanks in advance!!![]()
wait how can i do this?
My monitor doesn't' have DYAC and its 240 Hertz monitor.
The XL2540, which you've quoted, supports a backlight strobing solution as per: https://www.rtings.com/monitor/reviews/ ... wie-xl2540hurryupabit wrote: ↑06 Dec 2025, 12:08My monitor doesn't' have DYAC and its 240 Hertz monitor.
What should i use?
My monitor has no DYAC, It has only Gsync from nvidia compatible no dyac its benq xl2540 240 hertz . So what do you ou recommend me to use?kyube wrote: ↑19 Nov 2025, 15:47The answer to your question requires a few sub-questions:hurryupabit wrote: ↑10 Nov 2025, 11:52Hello everyone!!
other noreflex
other no vsync,sync
• Do you prefer using Dyac? (flicker/impulse-based approach)
• Do you prefer not using Dyac? (sample & hold approach)
Considering that your base vertical frequency (refresh rate) is way too low to use Nvidia's automatic frame rate limiter, which gets applied when using GSYNC&VSYNC&Reflex in conjuction with each other, I suggest that you try for one of these 2 approaches:
Impulse-based approach
Dyac=Premium
AMA=High or Premium (2 concrete preset overdrive settings)
Nvidia's 'Max Frame Rate' limter set to 480FPS or higher OR fps_max 0
Nvidia Reflex (in-game toggle)=Enable
I suggest against enabling Nvidia's Ultra Low Latency Mode in the Nvidia Control Panel, as it's meant to be used in games which don't implement Reflex (which uses in-game data to keep the render queue depth < 1 & thus eliminate what's referred to as 'GPU limited' scenarios)
Pros:
+Severe eye-tracked motion blur reduction (to ~800Hz)
+FPS>=Hz scenario eliminates the timing mismatch backlight strobing motion visual degradation
+Low render latency due to high frame time target
Neutral:
-'Tearing' (mismatch between frametime & refresh rate) artifacts may be unappealing
Cons:
-Light flicker from global scan backlight strobing (DyAc) can be a eye-strain concern.
-Additional processing latency penalty may occur
A bit more to read into: viewtopic.php?t=3555
Sample & hold based approach
Dyac=Off
AMA=High or Premium
Nvidia's 'Max Frame Rate' limter set to 480FPS (or to a value you can consistently get with your rig) OR fps_max 0
Nvidia Reflex (in-game toggle)=Enabled
Pros:
+No processing latency overhead from backlight strobing
+No rapid light flicker from backlight strobing
Neutral:
Cons:
-4,17ms pixel visibility time ('persistence') is still too blurry for some, most noticable when spraying
Here's a similar write-up I've done to above, but for frame rate locked games: viewtopic.php?f=2&t=14912#p118346
General notes:
I'd suggest only considering the use of the GSYNC&VSYNC&Reflex combination only on +540Hz TN models, as they have sufficiently high refresh rate to encapsulate the general frame rate values you'll be on when using a X3D-based microprocessor in CS2.
For CS2, from my rudimentary 'evaluation' using RTSS' reflex.ovl overlay preset:
fps_max (internal frame rate limiter), RTSS Reflex & Nvidia's Max Frame Rate (referred to colloquially as “NvLimiterV3”) are the only 3 options which don't affect the metric called “Nvidia Reflex Sim-to-Render Latency” (in reflex.ovl) with an additional frame of added latency. To word it differently — there is no added 'frame of latency' overhead with these 3 above.
This above was done with NVidia Reflex (in-game toggle)=Enabled.
I don't know whether the same behavior applies when Reflex is toggled off, as NvLimiterV3 behaves differently when Reflex isn't enabled.
Other external limiters (RTSS front-edge & back-edge, RTSS async) increase the “Nvidia Reflex Sim-to-Render Latency” by 1 or 2 frames of added latency.
Special-K is not usable, as most users who play CS2 use FaceIT, which is a kernel-level access anti-cheat client.
EDIT (10-01-2026):
Reflex in CS2 is non-functional when in HW:FLIP
Swapping to HW:Legacy Flip (by toggling disable FSO in 'Properties') completely fixes the behavior of Reflex in CS2.
Open up FrameView and test yourself. Look at the Render Queue Depth column.
I've already replied to you above....hurryupabit wrote: ↑27 Jan 2026, 11:18My monitor has no DYAC, It has only Gsync from nvidia compatible no dyac its benq xl2540 240 hertz . So what do you you recommend me to use?
Can you help me with this : -> EDIT (10-01-2026):kyube wrote: ↑27 Jan 2026, 12:15Open up FrameView and test yourself. Look at the Render Queue Depth column.
No frame rate limiter (fps_max 0) & fixed refresh rate.
Enable Reflex.
That's the best you can do, assuming tearing is irrelevant to you.
