Zowie XL2546K horizontal image breaks at 450+ FPS even walking forward (DyAc OFF/ON)
kyube
Re: Zowie XL2546K horizontal image breaks at 450+ FPS even walking forward (DyAc OFF/ON)
Post by kyube » 08 Feb 2026, 05:52
kraz wrote:
07 Feb 2026, 22:57
With RTSS Scanline-Sync, it's like night and day, no tearing.
240 is the lock for RTSS.
When I lock it to 240, there are still tearing and it feels like there's more system lag.
Scanline-sync comes with cons. Any external frame rate limiting solution increases total system latency by 1-2 frames (4,167 – 8,334 ms)
It's why I recommended GSYNC+VSYNC+Reflex instead as the #1 solution.
kraz wrote:
07 Feb 2026, 22:57
It's also really strange that on bots, when I'm running at 400 fps, the lag feels worse than with RTSS Scanline-Sync.
Have you checked your system for instabilities (CPU, GPU,..) and have you checked whether your display is frameskipping by any chance?
kraz wrote:
07 Feb 2026, 22:57
Tried HDMI and DP. Mouse 1kHz and 2kHz too.
You should be using DP on your display model.
kraz
Post by kraz » 08 Feb 2026, 07:16
kyube wrote:
08 Feb 2026, 05:52
kraz wrote:
07 Feb 2026, 22:57
kraz wrote:
07 Feb 2026, 22:57
kraz wrote:
07 Feb 2026, 22:57
The monitor doesn't skip frames. The white square goes through all the squares, but it leaves a residual image in the previous square. This is probably normal for TN.
What do you mean "check for stability"?
I've tested everything I could—OCCT, games, benchmarks.
Everything's fine.
I'm checking system latency with XTW, but I only discuss the results with AI, and that idiot rarely says anything useful.
In general, there are no problems in any games as such, but I can’t figure out what is a problem and what is not.
kyube
Post by kyube » 08 Feb 2026, 07:33
kraz wrote:
08 Feb 2026, 07:16
I assume you've checked with a camera with the appropriate shutter speed setting, therefore I will consider this checked
Then that just means you're sensitive to 'tearing'.
GSYNC+VSYNC+Reflex is your solution. Make sure to set your game in FSE (HW:LFLIP) instead of FSO (HW:IFLIP)
Ideally, you'd get a +540Hz TN and use the combo above, so you encapsulate your possible system's frame rate within your display's refresh rate.
kraz wrote:
08 Feb 2026, 07:16
Everything's fine.
Exactly what you've mentioned. I only wanted to mention it, just in case.
kraz
Post by kraz » 08 Feb 2026, 08:40
kyube wrote:
08 Feb 2026, 07:33
kraz wrote:
08 Feb 2026, 07:16
kraz wrote:
08 Feb 2026, 07:16
Everything's fine.
Thank you so much for taking the time!
Yes, the recording was done in 240fps slow motion with frame-by-frame stopping.
I'll tryFSE (HW:LFLIP)
kyube
Post by kyube » 08 Feb 2026, 09:30
kraz wrote:
08 Feb 2026, 08:40
I'll try FSE (HW:LFLIP)
It's important that you set the appropriate shutter speed, as per the https://testufo.com/frameskipping instruction.
Just to be sure, are you running the game in DirectX 11 or in the Vulkan API?
kraz
Post by kraz » 08 Feb 2026, 18:45
kyube wrote:
08 Feb 2026, 09:30
kraz wrote:
08 Feb 2026, 08:40
"Here is what I've noticed. My monitor has overshoot even with overdrive set to 'Minimal' (which is 'AMA Normal' on Zowie). I lowered it via the Service Menu from 6 (Normal) to 4. The overshoot is almost invisible at 960 px/sec. It becomes more noticeable at 1920 px/sec, and at level 2, it's clearly visible.
Regarding frame skips: yes, that was my mistake. I followed the instructions and everything is perfect now. There are 8 squares moving in a snake pattern without any interruptions."
hurryupabit
Post by hurryupabit » 20 Apr 2026, 14:03
i have benq lx2540 240 hertz gsync(from nvidia) , also reflex enable or disable? fps_max 0 ?
