In order from most impactful to least impactful. They all were impactful though.
- Regedit Tweak 1. Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Multimedia\SystemProfile Set Systemresponsiveness to 0. It was explained to me that it makes the system respond faster. The original value is 14 , and value 0 is more responsive. I noticed it was absolutely a difference.
- Control panel tweak. Keyboard setting found in control panel. Can be found in Microsoft search bar by searching for "keyboard". Set repeat delay and repeat rate all the way to the right. When you hold down a key it has no delay for the 2nd letter, which is great for gaming, but for typing it can create repeat letters because it's so instant.
- Regedit Tweak 2. Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\PriorityControl Win32PrioritySeparation set to 36. People strongly suggest not to go beyond 40 because it can have issues. I set it to 80 which is marginally more smooth, and it's been fine for a month or so. Go beyond 40 at your own risk. It was explained to me that the value is how much time the CPU spends on the foreground app, which is the game.
- Regedit Tweak 3. Computer\HKEY_CURRENT_USER\Control Panel\Keyboard InitialKeyboardIndicators:0 KeyboardDelay:0 KeyboardSpeed:31. It makes the keyboard react more instant. 31 is the highest value for keyboard speed.
Those are the ones I found to be effective. Use at your own risk, and create a restore point before hand. Consider sharing your top tweaks!
