cs2 input delay
Re: cs2 input delay
Post by Chief Blur Buster » 26 Feb 2026, 06:01
lyar wrote: ↑
26 Feb 2026, 00:49
My uncle uses an AV Receiver when he uses his TV, and it is usually always on. When he watches TV and leaves everything on my game is not playable at all. The weeks he is away from home for work, my games feeling is considerably better overall, despite some inconsistencies. Also when the laundry machines are in use my game has this same inconsistent feeling, even if short-lived. I have had this input lag problem with my NIC disabled in device manager and on many computers, mice, keyboards, and monitors over the years in several locations in Vancouver BC so I believe I am dealing with harmonic distortion in my area
Upgrading your computer power supply (e.g. Seasonic, etc) also can help keep some interference at bay too, but disconnecting from the grid helped some people. A big battery for your computer.
You might want to see the Electrical Interference discussion forum about offgridding your rig as a test. A 12.8V 100AH (1200 watt-hour) lithium iron battery and a kilowatt inverter can now be had for just a few hundred dollars (under $300 total if you shop around). And much cheaper to DIY than a Jackery Power Station or similar. Or just get any of those kilowatt-plus sized ANKER/Ecoflow power station on wheels (more expensive but you can take it camping or power your fridge in a blackout).
A giant version of your mobile phone power bank. A long-duration unplugged UPS essentially. But for a whole gaming rig that lasts about 3 hours battery powering RTX 5080 at 480Hz. Or more, if you get one of those bigger power stations on wheels about the size of a clothes hamper -- those bigger 3-kilowatt-hour batteries will power a whole gaming rig for about 5-10 hours.
This is beyond scope of this discussion forum topic area, so you'll have to discuss electrical-related latency issues in that other forum - viewforum.php?f=24
Be noted, some threads are a bit "out there", but dirty electricity do create legitimate performance-problems (interference -> error correction -> random jitters/latencies in various cabling like Ethernet or USB and even internally inside the computer, motherboard, and GPU -- performance throttled during interference situations, voltage instability, etc). With problems often still happening even if you keep your data cables far away from your power cables / power bricks / power supplies.
It may be solely on the DSL/cable line, but if you have fiber to the home -- you can get fairly good chances with a big kilowatt-hour league battery for your computer. Zero copper touching the grid (battery powering your rig + fiber media converters instead of Ethernet cable) and at least a two foot gap between the computer and the walls (keep away from electrical wiring). Put your fiber router into the offgrid bubble too. Get high end shielded USB cables and/or try a high-rated wireless mice/keyboard instead since cables acts as antennas from the mini-EMP's coming from elsewhere such as from home theater speakers, in-wall electrical wiring, and from dryer motor. Be noted, one may work better than the other (depending on whether your problem is wireless interference vs wired interference)
No electrical replies here to me please -- I temporarily waived the rule to reply to you -- any replies; please post in the other area.
netborg
Re: cs2 input delay
Post by netborg » 26 Feb 2026, 09:57
@Chief Blur Buster
With all respect, way too many users here are suspecting EMI when the reason for their issues 99% of the times is just that the software stack has gotten so complex that it is rarely aligned perfectly - which is a shame, as the software devs should pay way more attention to detail in this regard. TV could also mean the internet connection gets tampered with.
I've solved part of the puzzle with my frame pacer ( https://github.com/netborg-afps/dxvk-low-latency ), which lets me play some games already perfectly with unrivaled smoothness and input lag, in some cases there are still issues related to the game's synchronization to the render thread which then drops smoothness and input lag performance.
Recently I've even checked out how my pacer would perform in CS2, it did absolutely great on Linux, for some reason not so much on Windows. Unfortunately Valve is restricting users to use the native Linux version - understandably for anti-cheat reasons (BE CAREFUL IF ANYONE WANTS TO TRY my pacer: it cannot be used for online play in CS2 and only works by using Proton in CS2 via `%command% -insecure`; possibly it could be useful though for troubleshooting as my pacer was lower latency and was much smoother than what they offer on Linux.
lyar
Re: cs2 input delay
Post by lyar » 26 Feb 2026, 21:33
26 Feb 2026, 06:01
lyar wrote: ↑
26 Feb 2026, 00:49
move this thread if you have to but, isn't a double conversion UPS superior to an off grid setup? it constantly regenerates a sine wave from the wall and isn't relying on a battery. i tried a really bad sinewave gopower inverter with a lifepo4 battery years ago and it wasn't that great but it definitely helped. https://www.bestbuy.ca/en-ca/product/v7 ... v/19636719 I came across this deal and it's probably the best solution for people with this issue, as its THD% output is 2-4%
Re: cs2 input delay
Post by Chief Blur Buster » 26 Feb 2026, 22:04
lyar wrote: ↑
26 Feb 2026, 21:33
Depends -- a good inverter can be superior to a poor double conversion UPS. Yes, inverter quality is a consideration. A much higher quality inverter would be better. But yes, a good double conversion (always online) UPS is roughly as good. Regardless, always overprovision. Run at well under 50% peak and have one with very good surge capability, for the dynamic power consumption of a PC.
Re: cs2 input delay
Post by Slender » 27 Feb 2026, 20:50
This forum is completely dead. It's the same old story every time. Aren't you ashamed to recommend garbage to people? Not a single UPS on the market will give you a pure sine wave.
soul4kills
Re: cs2 input delay
Post by soul4kills » 27 Feb 2026, 23:48
Slender wrote: ↑
27 Feb 2026, 20:50
The audio industry is a very robust industry where they put lots of time and engineering into their tools and equipment. A lot of thought is put into minimizing interference and an online ups is usually their go to tool to solve these interference issues. Just some food for thought.
Edit: This actually reminded me of a video about ground loops. Where an improperly grounded devices can cause huge amounts of interference. Here's 2 videos that go into the problem in detail.
https://www.youtube.com/watch?v=einxGsiuwso&t=316s
https://www.youtube.com/watch?v=DSxvNtW5n6c
Pretty much what the videos imply is your interference problem could be as simple as a poorly grounded device plugged into the computer. And could be solved simply by unplugging it.
lyar
Re: cs2 input delay
Post by lyar » 28 Feb 2026, 11:48
Slender wrote: ↑
27 Feb 2026, 20:50
Calamity made FPLC in 2023 on an off grid battery inverter setup. What’s with the hostility?
Key word is off grid because he is no longer affected by potentially bad neutral to ground or the grids sine wave.
his sine wave inverter was good enough that he made FPLC when it still existed.
At my location I am unsure if it is harmonics or distorted sine wave anymore. My neutral to ground and ground to copper (water pipes) are not bonded and their values are not the same. This is technically a code violation and my wall ground is technically floating
Re: cs2 input delay
Post by Slender » 01 Mar 2026, 05:37
lyar wrote: ↑
28 Feb 2026, 11:48
Slender wrote: ↑
27 Feb 2026, 20:50
you not understand what is harmonic and emi, IT NOT YOUR WALL SOCET, WAKE UP.
Re: cs2 input delay
Post by Slender » 01 Mar 2026, 05:38
soul4kills wrote: ↑
27 Feb 2026, 23:48
Slender wrote: ↑
27 Feb 2026, 20:50
Any audiophile would simply kill you if they heard a recommendation about a UPS.
f1ndus
Re: cs2 input delay
Post by f1ndus » 01 Mar 2026, 05:52
Slender wrote: ↑
27 Feb 2026, 20:50
Yes all the years its everything the same not only there on blurbusters but also on input lag discord groups, people tried everything already to fix this issue, like me..
