Hello Blur Busters community,
My friend is experiencing the issue shown in the video linked in the URL. He has already tried almost everything — reinstalling Windows, applying various tweaks, and other troubleshooting steps — but nothing has helped.
He has been unable to find a solution for 9 months. The last thing that temporarily helped (it worked properly for about 4 days) was disabling the System > Display > Graphics > Optimizations for windowed games option.
Problem on youtube called "cs2 screen wide almost transparent line issue"
Pc specs: 9800x3d, asus rog 5070ti, x870e-e and zowie 2566x+ 400hz.
We would be grateful for any help.
Ziehesh
dealersweet
Re: cs2 screen wide almost transparent line issue
I have the same issue on high refresh monitors. Try testing different refresh rates (240/360/400 Hz) and another DisplayPort cable. Also check if it appears in OBS recording — if not, it may be a panel/scanout issue rather than CS2 itself.
