What's broken with the Pulse Width slider in the higher refresh rates? Seems to act the same way to me 10-100 adjustment and reduces brightness in the same way the 60hz mode does.kyube wrote: ↑19 Mar 2026, 10:31Where have you managed to contact Nvidia?
I'm hoping that they:
• Finally unlock full BW to HDMI 2.1 FRL6, instead of FRL5.
• Allow wider duty cycle range (or fix the PW slider?) in ULMB2 mode for 120Hz, 240Hz & 360Hz (so one can push much shorter duration strobe on periods, which is much easier on higher refresh rate)
brownvim
- kyube
viewtopic.php?t=15149&start=580#p123478
According to your anecdote here, this should never be the case if the allowed duty cycle range is identical between all refresh rate modes.
360Hz @ 10% duty cycle → 2,7778 ms * 0,1 = 0,27778 ms strobe 'on' period; 1000 / 0,27778 = ~3600 Hz “effective refresh rate”
60Hz @ 10% duty cyle → 16,6667 ms * 0,1 = 1,6667 ms strobe 'on' period; 1000 / 1,6667 = ~600 Hz "effective refresh rate"
As you can see, 360Hz should scale much faster to better clarities than 60Hz, which isn't the case in practice.
For 60Hz to be crystal clear at 2880 px/s (Hz), you'd need to have a strobe 'On' period of of 0,34722 ms
That requires a 2,08333333291667 % duty cycle @ 60Hz.
As per anecdotal data from here, at ~1700 cd/m² voltage boosting, that's ~35 cd/m²
My claim is that 360Hz only has a "allowable" duty cycle range of, at best, x–25% PW
60Hz can get to x–2% PW.
Sadly, TFTCentral hasn't given a strobe on & off period table for the QHD@360Hz Pulsar models, which he did for his previous KTC M27P6 review...
Argus
That's unfortunate.kyube wrote: ↑18 Mar 2026, 11:22Yes, single head limit of the DP1.4 port on 20/30/40 series cards.
ToastyX wrote: NVIDIA and DSC - ToastyX Wrote:
NVIDIA's driver currently ignores EDID overrides if Display Stream Compression (DSC) is active and the maximum resolution @ refresh rate combination exceeds the GPU's single-head pixel clock limit:
GTX 1600-series: 1330 MHz
RTX 2000-series: 1330 MHz
RTX 3000-series: 1335 MHz
RTX 4000-series: 1350 MHz
RTX 5000-series: Not affected
Workarounds:
SRE can add custom GPU-scaled resolutions but not custom refresh rates: https://www.monitortests.com/forum/Threa...Editor-SRE
Use RegEdit to disable using multiple heads, but the pixel clock will be limited to the single-head limit:
Key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4d36e968-e325-11ce-bfc1-08002be10318}\#### (usually 0000)
Value: "EnableTiledDisplay"=dword:00000000
Is there no way to disable DSC on the Acer model for now?
liquidshadowfox
who told you?
- kyube
Your only option would be to wait for Nvidia to release 2nd firmware update, to reap the benefits of the higher BW HDMI port and the fixed VRR+strobing implementation (which, according to brownvim, is planned to happen at some point in the future)
You could technically 'disable DSC' by running QHD@240Hz through DP1.4.
That's within the limits of DP1.4, as per this calculator
The HDMI 2.1 port is FRL5, according to TFTCentral, which isn't enough to drive QHD@360Hzkitabatake_radeka wrote: ↑19 Mar 2026, 07:361. Does the new firmware update allow for full bandwith via HDMI 2.1, i.e. no DSC? I guess bandwidth limitations would still make only 240 Hz viable with no DSC, but that is more than enough. If not, is the firmware update worth it anyway, if I am not interested in the new fixed 60 Hz mode?
DP1.4 and the FRL5 port are able to achieve QHD@240Hz though. I don't know whether the latter port would work with Pulsar and/or ULMB2
I'd start with January 7 2026 as a cut-off date up to today.kitabatake_radeka wrote: ↑19 Mar 2026, 07:362. I generally had the experience the newer the NVidia drivers after 572.83 the worse. What is the oldest driver fully compatible with the pulsar technology, and does it differ between the original and the new firmware?
This limits you to 591.74, 591.86, 595.59, 595.71, 595.79
I'd stick to GPU scaling.kitabatake_radeka wrote: ↑19 Mar 2026, 07:363. In the control panel, is it better to set the scaling by GPU or by the monitor? I never had a monitor with a dedicated GSync chip before, so I standardly use GPU scaling, is there any difference here?
SpecialK is one of the best external frame rate limiter solutions on the market.kitabatake_radeka wrote: ↑19 Mar 2026, 07:364. What is the best framecapping method to use with this monitor? Right now, I am using Special K and the Latent Sync limiter (no VSync, tearing ON) with the 1/2 refresh rate option (so approx 179.99 FPS) in most games; with the 1/3 refresh rate option (so approx 120 FPS) in the games that struggle to get above stable 130 FPS in QHD (such as Hell is Us).
SK's Latent Sync is likely redundant, as you're using VRR+Strobing (Pulsar) already to combat tearing.
It depends what you mean with "best":
- Best for total system latency? SK (with Reflex injected, to lower the depth of the render-ahead queue)
- Best for tearing management in VRR use? Not necessary
- Best for 'smoothness' (pacing)? SK
brownvim
A guy on Overclockers Forums, I think he works for TFTCentral, has direct contact with Nvidia Pulsar developers.liquidshadowfox wrote: ↑19 Mar 2026, 13:15who told you?excited that this monitor will get another firmware update to fix pulsar. Any word on release date? I assume it might take them another 3 months before we see the update.
No idea when it will be fixed, i'm just glad we got a response.
He mentioned Nvidia Pulsar devs actively check the BlurBusters Forums so I think they will be aware of all the issues and Kyubes moaning
brownvim
I have updated to the latest Nvidia Drivers 595.79, the previous ones had issues but its been fine now.kitabatake_radeka wrote: ↑19 Mar 2026, 07:36Hello, I also have this monitor.
I had a little trouble getting it working, as with me using the 572.83 driver on a 5090 there were random black screens in games when connected via DP 1.4 (and HDMI 2.1 was limited to 120 Hz), so I updated to the 591.86 driver and everything seems to be working fine now, 360 Hz 10 bit depth HDR when connected by DP 1.4 (still using the original firmware it came with). But I still have few questions which hopefully someone of you will know answer for:
1. does the new firmware update allow for full bandwith via HDMI 2.1, i.e. no DSC? I guess bandwidth limitations would still make only 240 Hz viable with no DSC, but that is more than enough. If not, is the firmware update worth it anyway, if I am not interested in the new fixed 60 Hz mode?
Stay on the older Pulsar firmware if you are not interested in the 60hz mode, its only worth it if your games are going to be above 180fps, anything below has introduced ghosting in the newer firmware. Which is in the process of being fixed.
Argus
So I'd need to downgrade my cable to disable DSC? I'm currently running a 2.1 DP and am able to select higher than QHD@240Hz.kyube wrote: ↑19 Mar 2026, 13:40Your only option would be to wait for Nvidia to release 2nd firmware update, to reap the benefits of the higher BW HDMI port and the fixed VRR+strobing implementation (which, according to brownvim, is planned to happen at some point in the future)
Piggybacking on the SK question cuz I'm interested in the smoothness and frame pacing aspect of SK. Is there a specific config I need to setup to best frame pacing? Thanks.
- kyube
No, you only need to set your resolution+refreshRate combo to QHD@240Hz. This should disable DSC.
If it doesn't disable DSC for you, it will definitely be disabled on HDMI 2.1 on new firmware(s)
The DP2.1 is backward compatible with DP1.4, that's not the issue.
Check out their wiki: https://wiki.special-k.info/Advanced/Video
The GUI, launched with CTRL+SHIFT+Backspace key combination, has tons of settings with descriptions of what they do.
Be aware that this is only a solution for games without a kernel-level anti-cheat.
Ones which do have a anti-cheat solution might flag you, you're in gray area.
7bhsq
So is 60hz single strobe in VRR mode just not happening anymore? Or has it been pushed back to the next firmware update?
