⚡eSports monitors and their secrets⚡
- naporitan
Re: AGON CS24A (only newer rev) / CS24A/P (only newer rev) | eSports scaler!!!
- naporitan
162 kpm
1728x1080 stretched
1.7 800 dpi Full(Square) mode
1728x1080 stretched
- naporitan
The best rifler in the world uses display scaling
DONK
DONK
vnb
i have been following your topic since you started it, and while i agree with most of what you said about monitor scaler, having experienced something similar myself with other monitors (same monitors but different .rev with different scaler performed drastically different)...
i have to be honest and think this last post about donk is maybe too far? also what is the point? I am sure you know that if you have a shit monitor scaler this is bad advice to everybody else, if you have good scaler it will work for them too.
but the only truth is that everyone got different monitors and depending on each Monitor; Display scaling may works better while for others GPU Scaling works better. So there is no definitive truth about this. Also just fyi in most case on Nvidia, Display scaling will always be worse while on AMD GPU both works really well almost the same.
I don’t know why but Display Scaling with Nvidia is broken while with AMD GPU it works way better... Nevertheless GPU Scaling is most of the time lower latency with both brands.
- naporitan
- naporitan
- naporitan
- naporitan
CS Asia Championships 2026
CS24A Rev 2025.12.11
Bepli
this might be outdated (if it is, please provide a source) but in the ESL setup guide he specifically states that he uses default Nvidia settings and ONLY switches ON GPU scaling and override scaling
Moontrance
Tbh I think it was wrong assumption from the beginning. EDID 600hz doesn't automatically means display scaling. Also I don't quite understand what "eSports scaler" could offer here, you still can't run 1280x960@600hz without DSC in DP1.4. In theory it makes sense if you lower refresh rate or resolution AND monitor scaler is as good as GPU scaler AND you don't want DSC.
