FPS cap causes stutter with gsync enabled
ren8542
Post by ren8542 » 25 Dec 2025, 06:41
the issue:
Whenever I cap my FPS, my frametimes become way more unstable. there are large stutters while panning the camera that dont happen when the FPS is uncapped.
Tested in 3 games. Cyberpunk and Clair Obscur were affected, while Dishonored 1 was fine. might have something to do with the implementation of newer features like gsync/framegen/reflex?
I upgraded my CPU and Monitor about 4 months ago. I'm not 100% sure but i think that's when this started happening. Also I noticed that the nvidia app FPS overlay doesn't show the same fps as my cap. Like if I cap at 120, the overlay shows 121 fps. this didn't used to happen back when this was working properly. 121 doesn't divide by 2, could this be causing issues with Frame Gen?
things that helped:
disabling gsync - frametimes are still less stable than uncapped, but the biggest stutters disappear
RTSS async cap - the frametimes become very smooth, but the latency is terrible
things ive tried:
updating drivers/bios/windows
in game fps cap, nvidia app fps cap, RTSS reflex cap
disabling frame gen
nvidia app vsync on/off
nvidia low latency mode off/on/ultra
disabling fullscreen optimizations
disabling windows 11 vrr/windowed optimizations
disabling HDR
clean driver install w/ DDU
driver rollback to v577
examples recorded in Cyberpunk (max settings w/ Path Tracing, 2x FG) with a 5070ti, 7800x3d, and AW2725DF 360hz OLED
uncapped:
Screenshot 2025-12-25 053045.png (80.8 KiB) Viewed 26537 times
capped:
Screenshot 2025-12-25 053209.png (90 KiB) Viewed 26537 times
capped+gsync off: (ignore the big spike, that was an autosave)
Screenshot 2025-12-25 054510.png (87.53 KiB) Viewed 26537 times
any help would be greatly appreciated, this has been driving me kind of crazy lmao
Re: FPS cap causes stutter with gsync enabled
Post by RealNC » 19 Jan 2026, 11:16
ren8542 wrote:
25 Dec 2025, 06:41
I noticed this myself in quite a few games in the last 3-4 years. Apparently some games, for whatever reason, can't handle it when render latency is 1 or 0, which is what happens when capping FPS below vsync rate. They seem to need at least a render latency of 2 or even 3 (which of course means 2 or 3 extra frames of lag.)
I don't know what causes it. Is it the games themselves, or did some change in the GPU drivers cause this? Or even Windows? No idea.
ren8542
Post by ren8542 » 28 Mar 2026, 12:03
RealNC wrote:
19 Jan 2026, 11:16
ren8542 wrote:
25 Dec 2025, 06:41
i wonder if it's something to do with having a monitor that lacks a gsync module. does your display lack one as well? my monitor isn't even verified as gsync compatible, it's "freesync premium pro". the nvidia app even warns me about this in the gsync section.
Post by RealNC » 28 Mar 2026, 12:41
ren8542 wrote:
28 Mar 2026, 12:03
No idea. Maybe the g-sync module helps. Mine doesn't have one (it's a "g-sync compatible" OLED display without a module.)
ren8542
Post by ren8542 » 06 Apr 2026, 21:22
RealNC wrote:
19 Jan 2026, 11:16
ren8542 wrote:
25 Dec 2025, 06:41
is this something that can be done with an app like display commander? it has an option called "max frame latency", is that the same thing?
Post by RealNC » 06 Apr 2026, 21:40
ren8542 wrote:
06 Apr 2026, 21:22
No. Render latency is the amount of buffered frames when you have hit the vsync ceiling. When you are FPS capping below the vsync limit, render latency is always 0.
My guess is that more and more games now have 1 or 2 frames long render stalls way too often, and the devs consider them normal because they assume a render latency of at least 2 to smooth out those stalls. Unreal Engine's "level streaming volumes" (aka "load zones") do this a lot. If traversal stutter results in a frame time spike that's less than 2 frames, then they consider the issue of traversal stutter as "solved" because render latency is going to make it invisible. Unless you use VRR with an FPS cap, then traversal stutter is very visible.
In other words, game devs (or engine devs) don't use VRR at all and don't care about it. Plain old vsync is still their target.
I could be wrong though, this is just an educated guess :mrgreen:
ren8542
Post by ren8542 » 09 Apr 2026, 03:34
RealNC wrote:
06 Apr 2026, 21:40
damn, that sucks. i appreciate the very detailed responses, thanks.
