I solved floaty mouse and input lag for myself (I really did this time around)
nickchraj
Re: I solved floaty mouse and input lag for myself (I really did this time around)
Charging 20$ with ai generated text and zero proof is insane.
mago
have u saw less gpu memory usage by dwm.exe ?
βΠΊπlΕ ΰΉπ’ α΅βΊΠΌπ‘Οο½ππβ, lΞ¬πΎ οΌ©π¬ οΌ¦π¬Κ³π’πΏα΄π―
Hyote
That's a weird thing to ask. I don't know but there should be less resource usage, especially with around 80% of the dwm threads disabled.
mago
why weird if dwm was bloaty its good indication
btw i also did same testing cs2 have same lower pcl and mouse feels better with this tweak
cant say im sure 100%
but there same good indications
Hyote
This is how they are auto suspended if they are chosen on my OS.
- 1000000370.jpg (4.67 MiB) Viewed 1393 times
mago
Code: Select all
dwm.exe, 13440, 0.13, 0.33, 12.19 kB/s, 105.46 MB, 488.61 MB, 6.62 MB, Window Manager\DWM-2, Desktop Window Manager, 3,319,612,551
csrss.exe, 13252, , 0.26, , 3.3 MB, 50.62 MB, 63.33 MB, NT AUTHORITY\SYSTEM, Client Server Runtime Process, 936,114,931
Server 2025 do better dwm.exe - 360mb - vram
win11 - DWM.exe 488.61 MB - vram
Hyote
Sounds cool, I might make a build.mago wrote: β15 Apr 2026, 10:20after logoffCode: Select all
dwm.exe, 13440, 0.13, 0.33, 12.19 kB/s, 105.46 MB, 488.61 MB, 6.62 MB, Window Manager\DWM-2, Desktop Window Manager, 3,319,612,551 csrss.exe, 13252, , 0.26, , 3.3 MB, 50.62 MB, 63.33 MB, NT AUTHORITY\SYSTEM, Client Server Runtime Process, 936,114,931
kimchi man
So you think the cause of the problem is Windows?
Hyote
No, but the difference a tweaked Windows can make is night and day. I don't deny EMI being an important factor, it just kind of doesn't matter for me anymore as my system is properly set up, so the effects of EMI are very minimal.
nickchraj
kkkkkk sounds like you just wanna make profit off us poor input laggers
