Russlan researchers figured it out
nickchraj
Post by nickchraj » 18 Apr 2026, 15:10
I’ve gone through most of the English-language discussions on input lag without finding a real solution, so I started looking into Russlan and Chinese communities instead.
I came across a Russlan creator who seems to have done extensive research on input lag potentially caused by electrical issues, like improper grounding. It looks like they achieved some positive results, but since I’m not fluent in Russlan, I couldn’t fully understand their conclusions. Judging by the comments under the video, though, they may have found a method to significantly reduce or eliminate the issue.
If anyone here understands Russlan, could you provide a brief summary or TL;DR for the community?
Here’s the video:
https://www.youtube.com/watch?v=MDCoWcpBB4Y
I strongly suspect my input lag is related to electrical factors, because I can reproduce it consistently. When I fully plug in my PSU and monitor power cables, I experience severe input lag enough to make fast-paced games unplayable. However, if I plug them in so the ground pin is barely touching, responsiveness improves significantly. I even had friends do blind tests, and they confirmed there’s a noticeable difference
kyube
Re: Russlan researchers figured it out
Post by kyube » 18 Apr 2026, 15:49
nickchraj wrote:
18 Apr 2026, 15:10
--random larp snip--
A 10$ device will surely be able to capture radiated & conducted noise... surely it must be that all the power quality companies & their electrical engineers are just stupid for buying $10k devices and $10k probes?
These meme gaming "tweakers" are hillarious to look at.
All you need in regards to this topic are these 2 posts:
post1 & post2
Everything else is a scam.
Notcoke
Post by Notcoke » 20 Apr 2026, 12:33
nickchraj wrote:
18 Apr 2026, 15:10
Here’s the video:
Have you tested using a "cheater's plug" to remove grounding connections on your devices? I read that this didn't work for some users, but this sounds like what you're doing by only partially seating your power cables.
nickchraj
Post by nickchraj » 20 Apr 2026, 12:45
Notcoke wrote:
20 Apr 2026, 12:33
nickchraj wrote:
18 Apr 2026, 15:10
Here’s the video:
Im hesitant to try this because its a little bit risky on components and on me :| but probably i will give it a try at some point, if there is any chance to solve this i will take it
kriegsnake
Post by kriegsnake » 20 Apr 2026, 23:52
Cheaters plug wont work in this situation. I’ve tried the method you used and i was top fragging first 6-7 rounds, then it degraded drastically. Simply unplugging display’s power cord midgame till it buzzers ( on the monitor side ) and plugging it back gave the same effect of fluidity. In my situation i don’t have a ground in my building at all, the grounding cable from the electrical meter not even connected anywhere.
So i come to only one conclusion in this case. Either we have to move to the proper apartment with grounding and connect it to the neutral on our box as couple of people mentioned before or play around with display cable or smth to release the static with our body or whatever is on the line.
dervu
Post by dervu » 21 Apr 2026, 09:37
No, they didn't figure a thing. Otherwise such solution would spread like fire, even if it was paid.
Give me a break, no one even uses proper scientific methods.
f1ndus
Post by f1ndus » 21 Apr 2026, 11:16
kriegsnake wrote:
20 Apr 2026, 23:52
Since you don’t have grounding, you most likely have a TN-C system where your neutral also serves as grounding, meaning it does two jobs at once. If you add grounding and switch to a TN-C-S system, interference and all negative effects will be reduced by roughly half on the neutral.
As i said many times, if you live in apartment [ shared building ] you have to move otherwise you will not fix it ever.
Notcoke
Post by Notcoke » 22 Apr 2026, 11:52
dervu wrote:
21 Apr 2026, 09:37
i'd still give him credit for figuring something out. you can't expect scientific methods from a group of gamers, man. IF the fix turns out to be something that requires you to wrap all your cables in foil... well, you know what, i'm just going to do that and move on. i wouldn't need to know in scientific detail why it works because for gamers, it's just important that it works.
