Hi,
I was wondering if BFI will produce ghosting like LCD strobing when you have lower fps than your refresh rate?
Novice question about BFI
- RealNC
Re: Novice question about BFI
Ghosting will be replaced by a double-image effect. The source of the double-image effect can be crosstalk (due to LCD pixel ghosting), or because the frame rate is lower than the refresh rate. See:supernovae wrote: ↑26 Apr 2026, 20:23I was wondering if BFI will produce ghosting like LCD strobing when you have lower fps than your refresh rate?
https://blurbusters.com/faq/advanced-st ... stalk-faq/
supernovae
Hi, double image and ghosting is for LCDs right? BFI is a black framr inserted in between, what happens when the fps is lower than the refresh rate in OLED case?
- RealNC
You get the double-image effect.supernovae wrote: ↑28 Apr 2026, 00:45Hi, double image and ghosting is for LCDs right? BFI is a black framr inserted in between, what happens when the fps is lower than the refresh rate in OLED case?
supernovae
Ok, thank youRealNC wrote: ↑28 Apr 2026, 10:55You get the double-image effect.supernovae wrote: ↑28 Apr 2026, 00:45Hi, double image and ghosting is for LCDs right? BFI is a black framr inserted in between, what happens when the fps is lower than the refresh rate in OLED case?
Demo of double images with software BFI: www.testufo.com/blackframes#multistrobe=2
supernovae
God it's so awful if you don't have the right fps..Chief Blur Buster wrote: ↑29 Apr 2026, 02:42Demo of double images with software BFI: www.testufo.com/blackframes#multistrobe=2
Thank you so much for sharing, really helped me make an informed purchase decision.
You guys are amazing!
