Same for me, gonna be fragging on a 9850X3D.
2025 Anti lag guide in getting new PC and hardware [video proof]
Hyote
Re: 2025 Anti lag guide in getting new PC and hardware [video proof]
Covtrixy
What's Ur recomended for my specs still have delay in my screen with AOC 600hz TN monitor!
My Specs:
Monitor:AOC CS24A 600hz TN
Mouse:Steelsseries Rivals 3 Wireless 1000hz Polling Rate
Keyboard:Keychron C3 Pro 1000hz Polling Rate
Windows 11 Pro (64bit)
Motherboard:Gigabyte B650M Gaming Plus Wifi
GPU:Gigabyte AMD RX 9060 XT 16gb (Overclocked)
CPU:AMD Ryzen 7 9700x 3.80GHz Overclocked to 5.50Ghz Undervolted -30 All Cores
RAM:Acer Predator Vesta II DDR5 Up to 6000MHz 32GB (16GBx2) RGB RAM CL30 Intel XMP 3.0 & AMD EXPO
SDD:Acer Predator GM6 1TB M.2 NVMe PCIe 4.0 SSD - Read Speed up to 7200MB
PSU:Gigabyte Power Supply Unit - 850W, 80 PLUS Gold Certified
Case:MAG FORGE 120A AIRFLOW 6 RGB Fans
CPU Cooler:upHere gaming UE2KC6 Black ARGB CPU Air Cooler
My Specs:
- BARGHEST
OMG, author, if you're so lucky and feel good in online and competitive games, that doesn't mean you know about the problem that's affected us here. You'll see when this crap gets to you. You'll wonder every day if you downloaded something wrong or if you're on a weird server. Oh well, the next one will definitely be better, but no! It will get worse and worse, and you'll get to the point where you'll only play at night if you can! And your post will get lost in the comments! Regarding what you wrote, that's complete nonsense! If you read on this forum that it's crap during the day and it's better to think logically during the day, if we move to a decent area where this crap won't happen, then the PC will improve, that's a fact! Should I buy a new PC I built for $2,000 and buy a less powerful system? Are you kidding me? Have you seen the prices for RAM?donger wrote: ↑30 Sep 2025, 08:58If you want your inputlag to be like on the video, read on:
Here are some scoreboards, the main point my skill is always the ceiling not how my hardware behaves:
https://imgur.com/a/CztmGzD
Seeing the amount of problems people are having with floaty mouse/lag i've decided to share my RIG which literally has ZERO issues. Forget the bulllshit seen on this forum from some schizos that wrong mousepad or less than 1000W PSU will cause inputlag lmao!!! I never have any lag, my mouse is snappy as fuck, the fps is so high and the frametimes are so low and consistent that you feel one with the machine/game. You can kill people like crazy with zero effort. Just copy my build 1:1 and you can start clapping people. As for the desync i am quite sure most of you just have shitty ISP and there is nothing that can be done about that unless you are willing to change your ISP which uses a different hardware endpoints. Anyways if you follow my guide in a creating a lag free PC and you still have problems then you have narrowed down that the ISP is the only problem.
[HARDWARE]
-Asrock b550 Pro4 UEFI ver. 3.40 Realtek RTL8111H eth controller
-5800x3d undervolted using negative offset in bios -30 all cores
-2x8 Patriot Viper Steel 4400MHz CL19 (ofc you have to set it to CL14/3600Mhz/1800 infinity fabric, or higher depending on the silicone lottery, my setting are attached)
-I've tested 5070Ti and 9070XT both were amazing.
-Corsair RM850x - ATX 3.1 - PCIe 5.1(keep in mind that the included 12V-2x6 connector is of a horrible quality and it's probably better to buy NZXT C850 Gold ATX 3.1)
-Archer AX53 1.5.4 fw.
-240hz monitor Acer Nitro XV272Xbmiiprx IPS (do not get an OLED if you play vision based shooters like Hunt Showdown, the blacks are so good you will have trouble seeing enemies in dark places)
[PERIPHERIALS]
-get a wireless mouse with either PIXART PAW 3395 or PAW 3950 which is popular and known to cause no problems. I have a MCHOSE G3 Realtek MCU ULTRA 8K receiver(more on pooling later)
-keyboard literally doesn't matter i was clapping people on 10$ office dell keyboard but if you really need to know i use Genesis Thor 404 TKL Kailh Brown)
-mousepad doesn't matter, personal prefference, i used Genesis Carbon and using SMX Speed Mouse Mat L Black which literally was 5$.
[WINDOWS AND SOFTWARE]
-do NOT install stock windows, it's literally one huge pile of spy and bloatware. Install a modded windows which is just barebones. I personally use W11 24h2 Ghost Spectre Superlite SE no Defender and having zero issues. If for some reason you don't wanna use it, do your own research and use something else. Do not use piece of shit stock windows.
-after installing fresh windows DO NOT install anything other than:
1. https://www.techpowerup.com/download/vi ... ll-in-one/
2.directX web installer update https://www.microsoft.com/en-us/downloa ... aspx?id=35
3.chipset drivers
4.GPU driver either minimal installation if you plan on gaming only or full install if you want to set recording shadow play/instant replay.
That's it!! Do not install any other bullshit like MSI afterburned which is known to cause stuttering for some people/games. Go install and play the game.
[MISC]
-do not use less than ~1500 DPI. It increases input lag for no reason. https://youtu.be/6AoRfv9W110?t=303
-do not crank up the pooling HZ to 8k barely any game supports that causing stuttering and your CPU usage will spike. Stay on 2K like i do and 4K only on games which you will test to cause no problems. 8K is snake oil and i have not found a single game working well with it.
-You do not have to spend hours in the registry changing god knows what, same goes for UEFI. This forum is filled with false promise clueless schizophrenics sharing the most placebo BS ever with ZERO proof.
-Always limit your fps, preferably to a number which will not leave you in a GPU bound situation, being in a constant GPU bottleneck will introduce additional inputlag #2. Ideally you should aim for stable fps twice as much as your refresh rate #1.
source#1 https://www.youtube.com/watch?v=hjWSRTYV8e0
source#2 https://www.youtube.com/watch?v=Fj-wZ_KGcsg
This is my first writeup, probably will modify it a bit later on. If you have some additional questions hit me up on discord "slick_dad" or comment here. Also please do not ask me about AM5 hardware simply because i don't have it yet and i do not know which ones will be lag free.I'll probably aim for a MOBO with Realtek eth controller not an intel one. I'll upgrade once the ryzen 10XXX will come out and let you know. Peace.
[MODERATION NOTE: A name-call was deleted from the topic line. It was in the topic line, so the rule violation flew under the moderation radar longer than expected. Apologies.]
donger
^ stop crying lmao i ain't reading this tantrum
donger
all my recommendations are in the original post, i recommend you to read it, this is not a troubleshooting thread, it's a list of known hardware with no perceivable lag + settings guidelines.Covtrixy wrote: ↑17 Apr 2026, 01:36What's Ur recomended for my specs still have delay in my screen with AOC 600hz TN monitor!
My Specs:
