Best 200$ monitor for esports
Andreww
Post by Andreww » 13 Apr 2026, 23:54
I'm looking for a 24~inch 1080p monitor. So far i have chosen these three:
ASUS VG259QM 280hz
ViewSonic XG2431 240hz
Alienware AW2523HF 360hz
Between these which one would be the best for valorant?
Cant afford a benq but i still need a decent antiblur/ghosting tech.
Would you recommend anything else in this price range?
Dalek
Re: Best 200$ monitor for esports
Post by Dalek » 16 Apr 2026, 08:28
I'd say the ViewSonic XG2431 if you don't mind strobe/BFI.
ASUS VG259QM if you want non-strobe.
kyube
Post by kyube » 16 Apr 2026, 08:56
Andreww wrote:
13 Apr 2026, 23:54
--snip--
You haven't mentioned the region you're purchasing from. I will give a general answer:
AOC Q25G4SR (or P245MS Pro, if you're in Japan / Russla) are the single best models that aren't OLED.
24" FHD should be avoided like the plague, regardless of use-case.
Dalek wrote:
16 Apr 2026, 08:28
This isn't 2021.
Both of those are archaic and garbage.
aurorasick
Post by aurorasick » 12 May 2026, 16:06
what do you guys think about the minifire mfg25f6q pro? great price if you are in europe and match the specs of the AOC Q25G4SR
