Fixing the color on the XL2411Z
michaelsgg
I just got my hands on a new monitor (XL2411Z) but after using blur busters strobe utility, I've lost a lot of color on csgo, I was wondering if anyone knew about something that could improve the color! Thanks mates!
- masterotaku
Re: Fixing the color on the XL2411Z
You didn't lose color. You lost brightness
. If you need the monitor to have more brighness, make sure it's already at 100, and then adjust persistence until you're comfortable.
Ambient lighting affects your perception of the monitor brightness. Keep your room a bit dark if possible.
Monitor: Asus PG278QR
kamill
Read about "vt trick".
