BLooDS_inc
Post by BLooDS_inc » 04 Jun 2026, 14:11
daviddave1 wrote:
04 Jun 2026, 12:15
BLooDS_inc wrote:
04 Jun 2026, 08:45
daviddave1 wrote:
04 Jun 2026, 03:58
Ok got the XG27AQNGV since yesterday also bought an RTX3080
My NVIDIA CTRL panel and monitor settings for Apex Legends ( that's a game that is hardcapped at 300 and fluctuates between 230 and 300 fps on 1440P and 1080P)
Nvidia Ctrl Panel settings
Nvidia driver 566.36
Low Latency Mode: Ultra
Gsync on
VSync off
2560x1440 x 360
Color: Override to Reference mode ( using icc profile MSIfanboy uploaded here last week)
Color Dept: 10 bit
Video Color setting Dynamic Range Full (0-255)
Video Image settings: Use the video player setting x 2. Deinterlacing Use inverse Telecine enebaled. RTX video enhancement: Disabled. High Dynamic Range: Inactive.
Monitor settings:
Standard firmware ( micro usb kabel is on the way)
Pulsar on
Pulsar Low FPS 120
Ambiend Apadative Brightness Off
Ambient Adaptive Color Off
Gamevials Racing Mode
Dark Boost Level 3
Aspect Control: 27" Default
Color Temp: 6500K
Display Color Space Wide Gamut
Gamma: 2.2
Apex Legends settings:
You guys think that once I have the micro-usb cable the firmware update will be beneficial for me ?
Does anyone has some other pointers please?
Update the fw when u can, ull see less bugs with pulsar, especially in low fps drops.
Don't use low latency mode ultra - it badly affects the 1% and 0.1% lows, use just ON, not ultra
Cap your fps under gsync range - if u play Apex and Apex runs under 300fps , use rtss frame cap with front sync edge capframe and set 300, ull see better fps and 1% lows and better framepace, better visual motion than nvcp cap or in-game cap
And i think use the latest drivers, except the very latest 610.47 that, like someone says, bring the gsync fps drop bugs and smooth motion bugs, I'm using the 596+ driver
Thank you! Did you try disabling DSC and play with 300hz with ULMB2 enabled but with Pulsar off? Is it worth the hassle in my situation u think? I like the 16:10 resolutions like 2304x1440 1728x1080
pulsar will be better anyway, mb just 60hz ulmb2 mode for 60fps is worth it with new fw
daviddave1
Post by daviddave1 » 04 Jun 2026, 14:19
I absolutely love this monitor. Best apex monitor I ever had. hands down. Still have some questions ^ but regardless
| Now: XG27AQNGV
mawi
Post by mawi » 04 Jun 2026, 14:22
liquidshadowfox wrote:
04 Jun 2026, 13:54
I mean by default you can run the monitor at 360 hz 8 bit color on a 3080 BUT some users have reported some black out issues due to being forced to run DSC to hit that refresh, resolution and color depth combination. Try it and see, worst case you can definitely run it at 240 hz and still have a similar experience. Pulsar doesn't work as well at higher fps than it does at lower frame rates ironically :) I normally play below 200 fps and everything looks incredibly clear compared to even my OLED monitor next to me.
Reducing refresh rate to 240 Hz does improve the situation, no more random black screens within games. But the alt+tab black screens are still there. If running at 240 Hz is really an option for anyone, I strongly recommend disabling displaytiling (see page 63 here). Everything just works better then.
Nvidia is aware of this situation and hopefully working on it. This is not a pulsar thing. If they get this under control they would improve a bunch of monitors.
brownvim
Post by brownvim » 04 Jun 2026, 16:40
In the next firmware update Nvidia mentioned they are reducing lag in the 240hz modes.
daviddave1
Post by daviddave1 » 04 Jun 2026, 16:48
04 Jun 2026, 13:54
daviddave1 wrote:
04 Jun 2026, 13:37
CriticalHit_NL wrote:
30 May 2026, 11:59
Mighty_opf wrote:
26 May 2026, 14:22
I performed a reinstallation this morning because I wasn't entirely sure if it had been applied correctly with FW 1.1.6, and I've noticed that it now correctly displays the FW version on the monitor's OSD: MCM103(V1.1.6).
Interesting, thanks.
I know the update did apply successfully since the 120-180 range is working fine now, was just curious why the firmware version sticked.
Maybe they did an inbetween fix, but not too bothered by it.
mawi wrote:
28 May 2026, 06:09
Interesting. Could it be that with 10bit color and 360 Hz, even RTX50 cards have to use multiple pipelines and run into the same problems as RTX40 cards with 360 Hz 8bit?
In this case... DSC is (again) not the actual problem.
You could try to disable the tiling via registry. With 8-bit color the 360 Hz mode should still be available. With 10-bit it could be gone.
RTX 50-series cards do not share the same limitation as DP 1.4 videocards did with DSC, that means even with DP1.4 monitor and cable you can use DSR / DLDSR (or custom resolution) and not have the same black screen issues as RTX 40-series and older experience.
You can also use 10-bit with VRR/Pulsar with HDR no problem. With DSR 'hacked' to 8K resolution you even get to keep the 360Hz output, I think at 16K it may be 60Hz but that is an exceptionally high resolution not workable in many games.
It runs on all RTX-50 series cards on a single display pipeline even though DSC is still active to compress the image to send it through to the display but the GPU side is well capable enough to handle all the bandwidth required.
So whatever issues you experience on DP 1.4 videocards may disappear using a newer videocard.
You can also see some more in depth explanations here to have an idea what each combination offers:
https://tftcentral.co.uk/articles/loads ... nd-updates
kitabatake_radeka wrote:
29 May 2026, 08:54
To circle back a little bit to my previous question: which driver would you recommend for the firmware 1.1.6 and an 5090 GPU?
I would probably advice to still install the latest one, unless you're experiencing issues you didn't on previous ones which can at times be a bit of a mixed bag between GPU architectures, though recently they have implemented some security updates for the drivers in May so I would still make sure to have atleast that version or newer installed for security.
https://nvidia.custhelp.com/app/answers ... --may-2026
I did have to install the 610.47 driver completely clean because I had issues with GTA V Enhanced not booting due to some strange underlying driver issue which may have been a result of doing multiple GPU driver upgrades in a row without a clean install which caused below crash errors in the launcher error logs:
[DISPLAY] [23800] [gamelaunch] Game exited with code 0xc0000005 (3221225477)
So what I did was wipe 610.47 completely including leftover folders, registry and physx + legacy physx.
Then I reinstalled the previous driver, re-imported my driver profiles with Nvidia App override bypass so I can control DLSS overrides in any game without Nvidia App resetting the driver profiles for those particular games.
The game functioned again afterwards with all my programs open + RTSS overlay.
After that I installed the 610.47 driver over it and install Legacy PhysX without doing a clean install and things are fine again.
Noteworthy, I had some stuttering issues on the Pulsar display in DOOM TDA with the previous few drivers on 3x/4x MFG mode, but that looks to be solved now in 610.47 with maybe the only leftover 'issue' being if you switch from a Legacy native FPGA G-sync monitor to the Pulsar display that 4x MFG may still exhibit some frametime stutters until you retoggle the MFG settings ingame.
Sometimes MFG behaves differently on the old G-sync monitor versus the Pulsar monitor even on different multiplier modes, but the recent updates in the drivers regarding multi-monitor with MFG and V-sync fixes may have contributed to this improved stability.
Only RTX-Remix games like Portal and Half-Life 2 still seem to stutter on 4x MFG mode (2/3x is smooth) making the motion feel like half the smoothness on 4x mode despite higher FPS even on DLSS Ultra Performance on a RTX 5090 which is a bit questionable why this happens when games like Cyberpunk 2077 have zero stutter doing even 6x MFG.
The 610.47 driver has not yet fixed the Stand-by -> wake up for G-sync on the PG279Q essentially deactivating it when woken up but that is to be fixed in the future, Pulsar does not show this problem.
But in short I would probably still go for 610.47, albeit a clean install and re-import your driver profiles if required through Nvidia Inspector.
I have a RTX 3080 its not possible right to make custom resolutions and have Pulsar enabled on 360hz 1440P 8 bit? is 240hz max?
Standard the monitor runs great on my 3080 8 bit or 10 bit 360hz with Pulsar only problem I have is that there is no custom res option. Is there a way to get the custom resolution available with Pulsar on 360hz 1440p?
| Now: XG27AQNGV
MSIfanboy
Post by MSIfanboy » 04 Jun 2026, 17:03
Yes you can make a cru custom resolution and use sre also, I used both, and pulsar still works , I had to turn off scaling in the osd , image, aspect control, scaling off
mawi
Post by mawi » 04 Jun 2026, 17:08
daviddave1 wrote:
04 Jun 2026, 16:48
Yes. Follow the guide on page 63, disable tiling. Besides the snappier operation without any alt+tab black screens this will allow you custom resolution and DSR (super sampling). Both are deactivated by default using rtx30 and 40 cards. I assume DSC (compression) is also deactivated.
You can run the display with single tile mode up to 300 Hz via custom resolution (8-bit and 10-bit). However, Pulsar only works with 240 Hz.
When tiling is disabled, you should not play around too much with adding other screens on the fly (like plugging in a new screen while running windows). That might cause some blue screens. After a restart however all screens will work then.
daviddave1
Post by daviddave1 » 04 Jun 2026, 20:06
mawi wrote:
04 Jun 2026, 17:08
daviddave1 wrote:
04 Jun 2026, 16:48
Tnx so Pulsar only works with custom resolutions on 240hz? I am confused cause msifanboy says he can use cru to make a 360hz custom res with 360 Hz just above this message
| Now: XG27AQNGV
daviddave1
Post by daviddave1 » 04 Jun 2026, 20:09
MSIfanboy wrote:
04 Jun 2026, 17:03
Tnx!!! so Pulsar works with custom resolutions on 360z? That's good news!! I am a bit confused though cause mawi says he can only make a 240hz custom res just above this message.
| Now: XG27AQNGV
MSIfanboy
Post by MSIfanboy » 05 Jun 2026, 02:50
daviddave1 wrote:
04 Jun 2026, 20:09
MSIfanboy wrote:
04 Jun 2026, 17:03
yes i am running 24.1 inch mode, pulsar works, scroll back to my former posts a few pages back
Screenshot 2026-06-05 174541.png (36.33 KiB) Viewed 841 times
