InputLag SOLVED Realtek USB / TP-LINK UE300 USB 3.0 Adapter
SammYrai
Re: InputLag SOLVED Realtek USB / TP-LINK UE300 USB 3.0 Adapter
Post by SammYrai » 10 Jun 2026, 05:31
just to be sure which driver should we be using with this ? the 2015 one or actual realtek ndis/netadaptercx?
Inputlagger91
Post by Inputlagger91 » 10 Jun 2026, 07:01
SammYrai wrote:
10 Jun 2026, 05:31
I haven't updated it, I don't want to take any risks. I left it in 2015, like the author.
Mr1991
Post by Mr1991 » 10 Jun 2026, 07:34
Not saying this is right or wrong, but interestingly, when I believe I had better input on my older systems I always used crappy USB wireless receivers, as I had no clue about hardware back then
Apexer15
Post by Apexer15 » 10 Jun 2026, 10:06
I have a (Hama) USB extension hub with a built-in HDMI and Ethernet ports that adds the Realtek USB GbE Family Controller to my device manager too but when I was playing on it the issue was still there.
But @Author, is your type C or type A plug?
vnb
Post by vnb » 10 Jun 2026, 10:31
vnb
Post by vnb » 10 Jun 2026, 10:32
vnb
Inputlagger91 wrote:
10 Jun 2026, 07:01
SammYrai wrote:
10 Jun 2026, 05:31
This is right !!!! Very important to keep the default one (2015) if i remember correctly this is a windows native netadaptercx firmware.
Apexer15 wrote:
10 Jun 2026, 10:06
I am not the autor but TP-LINK UE300 Adapter is type C.
Avoid usb extension with multiple ports like yours. Best extension you can buy is 1 function only (in this case ethernet only).
Also your motherboard may not be affected by this issue at all. It really depends because each motherboard model has a different topology, yours may be good? Only way to tell is test with an ethernet extension to type C, if nothing changes, your issue isn't here.
[/quote]
Rezurrectsz
Post by Rezurrectsz » 10 Jun 2026, 10:46
Is the type C one fine, or do I need the usb A?
Apexer15
Post by Apexer15 » 10 Jun 2026, 11:20
Thanks for the reply but seems like there are 2 models, type C and a type A one. I want to know which one the author is using
also I mainly bought it because I use it on a handheld PC where there's no Hdmi port because I really needed it connected to a bigger screen.
Inputlagger91
Post by Inputlagger91 » 10 Jun 2026, 22:40
I have a type-A adapter. But I also have some observations that make me doubt that the adapter was the reason for my success. I will write about this in more detail later.
