ExplodinFistz
Post by ExplodinFistz » 12 Jun 2026, 09:16
RealNC wrote: ↑
12 Jun 2026, 08:47
It doesn't matter if you force vsync in the driver or not. If vsync is used, Reflex or the "ultra" low latency setting will apply a VRR cap to prevent vsync lag when using g-sync.
Oh interesting. Then in my case reflex would be enabled. Low latency mode is turned off. It is curious though because in RTSS it says my optimal VRR cap is at 228 FPS, in contrast to reflex which configures it to be 225 for my monitor's refresh rate of 240 Hz. RealNC, you have the same XG27AQDMG monitor as me correct? What VRR frame cap does RTSS report to you? I guess reflex and RTSS calculate with different formulas which would explain the discrepancy.
Screenshot 2026-06-12 091036.png (65.67 KiB) Viewed 4206 times
Post by RealNC » 12 Jun 2026, 20:15
ExplodinFistz wrote: ↑
12 Jun 2026, 09:16
Yeah. Reflex uses this formula:
Hz * 3600 / (Hz + 3600)
RTSS uses something else.
knypol
Post by knypol » 17 Sep 2026, 09:57
What gives best effect in smoothness: gsync + vsync (NVCP) or gsync + rtss fps cap?
Post by jorimt » 23 Nov 2026, 15:56
knypol wrote: ↑
17 Sep 2026, 09:57
Technically, purely where "smoothness" is concerned, G-SYNC + NVCP V-SYNC + RTSS FPS limit.
G-SYNC + RTSS FPS limit without V-SYNC can still tear, and visible tearing artifacts (however slight or infrequent) can = less "smooth."
Displays: ASUS P27UCWM, LG 48C4 OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboard: Wooting 60HE v2 Mouse: Logitech G Pro X2 SUPERSTRIKE Sound: Creative Sound Blaster Katana V2 VR: Beyond 2, Quest 3, Reverb G2, Index Consoles: N64, Analogue 3D, Dreamcast, PS2, PS3, PS5 Pro, Switch 2, Wii, Xbox, Xbox 360, Analogue Pocket + Dock Scaler: RetroTINK 4k
