fa1kk wrote: ↑03 Jul 2026, 04:40
issawm wrote: ↑03 Jul 2026, 00:26
“ Over the years, the same pattern has happened on multiple different PCs, including brand-new ones: the systems are fully capable of feeling normal at first, proving the hardware can provide the mouse feel you’re looking for. Then, after Windows updates or related software changes, the mouse begins to feel floaty again. Because this has repeated across multiple systems, it’s unlikely to be bad hardware or bad luck. The more likely explanation is that a software, driver, firmware, or Windows configuration change is consistently altering how the system behaves after setup. The goal is to identify the specific change that happens between the system feeling normal and it becoming floaty.”
I’ve spent $500 on ChatGPT over the course of 3 years. Yet no leads or anything remotely close and this is all I got in the end..
I have a different perspective on how software, drivers, and firmware can affect latency and responsiveness. They absolutely can. Different drivers and software can all change how a game feels.
In the same Windows, my game can change from "bad" to "worse" without a single software update, reboot, or driver change. It changes within seconds while the PC is running, and not a single reboot or CMOS reset can help; a full reset of the OC never helped either.
More importantly, the monitor itself changes. Motion clarity, perceived blur, image sharpness, and brightness all change together with the mouse feel.
After years of testing, I don't see evidence that it is the root cause. At most, software seems capable of amplifying or reducing an already existing condition rather than creating it.
TLDR: I can do whatever I want with the system, but if I have a random improvement on the monitor and mouse, no matter what I do, it will be there.
This is so true, hence why I have given up on tinkering with bios and the OS altogether for a while now.
Nowadays I run completely stock and don’t bother with anything, sometimes even run my ram at JEDEC speeds for weeks until i can be bothered changing it. As long as I make sure my system is stable (no crashes, BSOD, driver incompatibility issues, etc) I observe that nothing I do ever influences my system positively and/or permanently.
Like you said even during the same session or at random hours during the day, motion clarity is great, monitor looks brighter, textures aren’t degraded, character model outlines and textures become visible and clear.
This inexplicable issue comes and goes, and happens whether my system is optimized (6000CL28 Hynix-A die manual OC’d profile which passed 8hrs of kharu and memtest, undervolted 9800x3d -20 all cores with a PBO OC, 4080Super) or completely stock.
The bottom line is that; it doesn’t matter how much I go out of my way to push my hardware or software side to its absolute limits, the gains and extra FPS/lower latency absolutely pale in comparison to when my system and peripherals magically decide to work properly one random day or night. Having experienced this unpredictable change, the difference between stock and optimized becomes redundant, almost a waste of time even.
