NVIDIA G-Sync Pulsar monitor - Acer Predator XB273U F5
brownvim
Re: NVIDIA G-Sync Pulsar monitor - Acer Predator XB273U F5
Post by brownvim » 08 Jul 2026, 07:14
nuninho1980 wrote: ↑
08 Jul 2026, 05:32
brownvim wrote: ↑
07 Jul 2026, 17:36
I think its possible within Windows, I made a custom resolution of 50hz with the CRU program and it seems to work, I would need someone else to confirm. CRU settings below:
I did play a 50fps video on YouTube and it looked smooth and clear: https://www.youtube.com/watch?v=-HqB15g_sCA&t=21s
Note this mode flickers even more than the 60hz mode! The 60hz mode flicker doesn't bother me but I think this would bother me using it an extended time.
The pulse width adjustments are still available in this mode too.
Checked UFO test and it confirms its 50hz, it also says on the Acer OSD that its running at 50hz.
Thank you!! :D I'm selling current ViewSonic monitor... Then I'll buy this Acer monitor in this month...
Best regards. ;)
I wouldn’t buy it for the 50hz mode, I can see why it’s not officially supported.
It has a lot of image retention.
nuninho1980
Post by nuninho1980 » 08 Jul 2026, 17:06
brownvim wrote: ↑
08 Jul 2026, 07:14
If it's "hardware" strobe, LCD doesn't suffer burn-in because LCD doesn't use flickering. LED backlight is (very) cheap but up to 60k hours of lifespan while LCD is very expensive but fortunately, between 100 and 150 years of lifespan. :)
RAM: 2x16GB DDR4@3600MHz
MB: MSI PRO Z690-A DDR4
GPU: Zotac RTX 4090 non-OC <3 :D
HDD: SATA 1TB
PSU: AEROCOOL 1kW 80+ Gold
Disly: ACER Predator XB273U F5 !NEW! :mrgreen:
brownvim
Post by brownvim » 08 Jul 2026, 17:28
Just to clarify, I meant image retention, not burn-in, which is a bit different.
What I'm seeing is that desktop icons stay faintly visible as an overlay when watching video, and it takes a while for them to fade away.
zenki
Post by zenki » 09 Jul 2026, 02:54
Anyone can help?
Didn't have the issue with other monitor.
Specs:
win10 21h2, rtx5070, acer XB273U F5 v1.1.8
nuninho1980
Post by nuninho1980 » 22 Jul 2026, 09:25
brownvim wrote: ↑
08 Jul 2026, 17:28
Ok. But 50Hz + HW strobing ( = LED strobing ) won't harm LCD screen because the temperature isn't high - only cooler than 35~40 ºC. But yes hotter than 60 ºC can degrade or ruin LCD. ;)
HDD: SATA 1TB
Post by Chief Blur Buster » 24 Jul 2026, 13:32
brownvim wrote: ↑
08 Jul 2026, 17:28
This is caused by bugs in the LCD inversion algorithm, if it's not caused by an even-count frame flicker frequency (e.g. software BFI, stereoscopic graphics, etc)
pgz
Post by pgz » 29 Jul 2026, 13:00
Woot.com has this monitor on sale. $379.99
https://computers.woot.com/offers/acer- ... itor-27z-1
https://imgur.com/a/yhrDB8g (some reason the img bbcodes are not working here)
RynoW
Post by RynoW » 29 Jul 2026, 15:06
Is there a reason not to go for this one over the others, given the price delta? The reviews on Amazon and Newegg aren't good but it's always hard to tell what is and isn't user error
pgz
Post by pgz » 29 Jul 2026, 15:37
RynoW wrote: ↑
29 Jul 2026, 15:06
I had this model before and did return it. But there was nothing wrong with it when I was using it. I used multiple models of the pulsar monitors now.
I would say this is a buy. I think it is just sitting and not selling maybe.
I returned it cause well, I didn't like the stand, and tried to the MSI model. But that model gave me a dead pixel. I returned the MSI one, and now I just bought his one.
edit: Price is now showing $369.99 instead of the $379.99 earlier today. I was able to call them back and get a refund.
pgz
Post by pgz » 29 Jul 2026, 18:14
Does anyone have the link for the actual manual for this monitor? I cannot find it at all.
