1 ROUTER 2 PC SAME SERVER PING DIFFERENCE 15MS
Re: 1 ROUTER 2 PC SAME SERVER PING DIFFERENCE 15MS
Post by Slender » 13 May 2026, 11:19
shebu wrote: ↑
06 May 2026, 16:18
type of connections?
standard rj45 from isp.
SammYrai
Post by SammYrai » 15 May 2026, 02:42
@slender I sent you a dm hope this helps
DudeBeFishing
Post by DudeBeFishing » 16 May 2026, 14:39
Try checking the path to the game server with trace route. It might not point to the problem, but if it looks normal for both PCs, then it's most likely a problem on the game server's side and not yours. Maybe it will help with your sanity.
  • - Open Resource Monitor.
    - Go to the Network tab.
    - Select / Check the game's .exe.
    - Take note of the Remote Addresses.
    - Open Command Prompt.
    - Enter this command without quotes, "tracert -w 200 -d address
-w 200 will limit the wait time per hop to 200ms. -d disables DNS lookup which is time consuming.
If there's multiple addresses, the server's address is most likely the one with the higher remote port.
Post by Slender » 18 Jul 2026, 02:35
SammYrai wrote: ↑
15 May 2026, 02:42
thanks!
I thought I had sent you a message, but I hadn't. By the way, I grounded the router, but that didn't solve the problem at all.
jassine
Post by jassine » 18 Jul 2026, 15:18
it could be the network card, try to use an external card on your pcs and test.
Post by Slender » 18 Jul 2026, 15:40
jassine wrote: ↑
18 Jul 2026, 15:18
bro, tried all of possible cards, windows, etc.
jassine
Post by jassine » 18 Jul 2026, 18:21
what are your PCs specs ?
Post by Slender » 13 Aug 2026, 22:59
jassine wrote: ↑
18 Jul 2026, 18:21
9700k 1080
9700x 3070 ti
niwhale
Post by niwhale » 14 Aug 2026, 12:00
Slender wrote: ↑
18 Jul 2026, 02:35
SammYrai wrote: ↑
15 May 2026, 02:42
thanks!
the problem is with this steam setting, you need to put "Never"
unconnected
Post by unconnected » 15 Aug 2026, 15:09
You'd need to understand where is actually the issue is coming from..
Get the relay ip thru task manager -> resource monitor
With WinMTR open and listening on the ip you gathered play for a couple of minutes.
Post result including the hops
