Incredible input, as usual xD
Xhci may be the culprit.
Vocaleyes
Re: Xhci may be the culprit.
Well, thats disheartening. More than likely back to the drawing board then.agendarsky wrote: ↑24 Jul 2026, 07:31none, except i don't ned to replug mouse after boot to get stable polling rate, there is some uefi - os pre-boot handshake bug where mouse polling rate won't go higher than 1000 or even go lower unless you unplug and plug your mouse back.
DudeBeFishing
Get a PCI/PCIe adapter and PCI USB card. There's far more PCI USB 2.0 cards available, new and used. Windows drivers might be a problem though.
Vocaleyes
…what a great idea!DudeBeFishing wrote: ↑25 Jul 2026, 00:26Get a PCI/PCIe adapter and PCI USB card. There's far more PCI USB 2.0 cards available, new and used. Windows drivers might be a problem though.
ablemor
Don't buy anything, I've tried this too and it didn't help, the problem is not xhci and ehci.
Vocaleyes
Can confirm. Ruled out entirely.
