⚡Potential fix for desync, input lag, floaty mouse, heavy car bug, etc.⚡
Locked
ablemor
Re: A possible fix or solution to the mystery of the problem
Post by ablemor » Yesterday, 08:06
naporitan wrote:
24 Jul 2026, 14:46
ablemor wrote:
24 Jul 2026, 14:35
try to play in fullscreen windowed mode
Why? You need to use fullscreen mode in games.
Because the render is different, and for anyone struggling with floaty mouse movement, it might help, mouse movement might change slightly because of DWM, it can become a bit more consistent.
naporitan
Post by naporitan » Yesterday, 08:09
ablemor wrote:
Yesterday, 08:06
No, everything should work as it should.
ablemor
Re: ⚡Potential fix for desync, input lag, floaty mouse, etc.⚡
Post by ablemor » Yesterday, 08:16
Test it, compare it, and you will see, it is different, example in fps shooter games
naporitan
Post by naporitan » Yesterday, 08:19
ablemor wrote:
Yesterday, 08:16
I play on Exclusive Fullscreen and have a good gaming experience, I will not be using the settings you recommend.
ablemor
Post by ablemor » Yesterday, 08:20
Then you are lucky, but if you are not struggling with any input lag, what are you looking for a solution for?
naporitan
Post by naporitan » Yesterday, 08:26
ablemor wrote:
Yesterday, 08:20
viewtopic.php?t=15406&start=30#p126512
These are solutions for those who are still experiencing problems, and I initially had all the problems with desync, floaty mouse, etc. And I immediately wrote about it in the topic.
ablemor I recommend you to work on yourself.
otherwise it feels like you're a double of yourself from the backrooms, who thinks in the most abstract way possible.
ablemor
Post by ablemor » Yesterday, 08:29
Don't suggest anything to me, you create useless topics, they make no sense.
Show people a little respect, and there's no need to get personal.
naporitan
Post by naporitan » Yesterday, 08:31
ablemor wrote:
Yesterday, 08:29
Don't be offended
naporitan
Post by naporitan » Yesterday, 13:24
Proof that I don't have problems with desync, floaty mouse, etc. I beat a 4000 elo player with 130 ping.
I'll post the video tomorrow.
https://www.faceit.com/ru/players/DAN9ARMATURA
https://www.hltv.org/player/26073/dan9armatura
dermodemon
Post by dermodemon » Yesterday, 13:58
naporitan wrote:
Yesterday, 13:24
dude.... you are just.... pathetic
Locked
