⚡Potential fix for desync, input lag, floaty mouse, heavy car bug, etc.⚡
naporitan
Re: A possible fix or solution to the mystery of the problem
Post by naporitan » 26 Jul 2026, 08:09
ablemor wrote: ↑
26 Jul 2026, 08:06
Because the render is different, and for anyone struggling with floaty mouse movement, it might help, mouse movement might change slightly because of DWM, it can become a bit more consistent.
No, everything should work as it should.
ablemor
Re: ⚡Potential fix for desync, input lag, floaty mouse, etc.⚡
Post by ablemor » 26 Jul 2026, 08:16
Test it, compare it, and you will see, it is different, example in fps shooter games
naporitan
Post by naporitan » 26 Jul 2026, 08:19
ablemor wrote: ↑
26 Jul 2026, 08:16
I play on Exclusive Fullscreen and have a good gaming experience, I will not be using the settings you recommend.
ablemor
Post by ablemor » 26 Jul 2026, 08:20
Then you are lucky, but if you are not struggling with any input lag, what are you looking for a solution for?
naporitan
Post by naporitan » 26 Jul 2026, 08:26
ablemor wrote: ↑
26 Jul 2026, 08:20
viewtopic.php?t=15406&start=30#p126512
These are solutions for those who are still experiencing problems, and I initially had all the problems with desync, floaty mouse, etc. And I immediately wrote about it in the topic.
ablemor I recommend you to work on yourself.
otherwise it feels like you're a double of yourself from the backrooms, who thinks in the most abstract way possible.
ablemor
Post by ablemor » 26 Jul 2026, 08:29
Don't suggest anything to me, you create useless topics, they make no sense.
Show people a little respect, and there's no need to get personal.
naporitan
Post by naporitan » 26 Jul 2026, 08:31
ablemor wrote: ↑
26 Jul 2026, 08:29
Don't be offended
naporitan
Post by naporitan » 26 Jul 2026, 13:24
Proof that I don't have problems with desync, floaty mouse, etc. I beat a 4000 elo player with 130 ping.
I'll post the video tomorrow.
https://www.faceit.com/ru/players/DAN9ARMATURA
https://www.hltv.org/player/26073/dan9armatura
dermodemon
Post by dermodemon » 26 Jul 2026, 13:58
naporitan wrote: ↑
26 Jul 2026, 13:24
dude.... you are just.... pathetic
naporitan
Post by naporitan » 26 Jul 2026, 14:14
https://www.hltv.org/player/26073/dan9armatura VS naporitan BLURBUSTERS
Locked
