InputLag SOLVED Realtek USB / TP-LINK UE300 USB 3.0 Adapter
Sandy
Re: InputLag SOLVED Realtek USB / TP-LINK UE300 USB 3.0 Adapter
Post by Sandy » 12 Jul 2026, 03:29
[link removed]
Post by RealNC » 12 Jul 2026, 06:34
Sandy wrote: ↑
12 Jul 2026, 03:29
[link removed]
I deleted this link. Can you explain what it was for?
Lev1n
Post by Lev1n » 13 Jul 2026, 05:58
Sandy wrote: ↑
12 Jul 2026, 03:29
[link removed]
can you send the link thru pm?
Sandy
Post by Sandy » 13 Jul 2026, 23:38
RealNC wrote: ↑
12 Jul 2026, 06:34
Sandy wrote: ↑
12 Jul 2026, 03:29
[link removed]
What did I send? I’ve forgotten—maybe I pasted the wrong thing?
Post by RealNC » 14 Jul 2026, 00:25
Sandy wrote: ↑
13 Jul 2026, 23:38
RealNC wrote: ↑
12 Jul 2026, 06:34
Sandy wrote: ↑
12 Jul 2026, 03:29
[link removed]
You've posted a link pointing to a custom port of a random server disguised as a github link.
wasted42
Post by wasted42 » 24 Jul 2026, 21:53
Unfortunately, the problem came back. I fell into depression because of it, i didnt visit forum and didnt give update, sry
Sandy
Post by Sandy » 24 Jul 2026, 22:41
wasted42 wrote: ↑
24 Jul 2026, 21:53
Yes, the network card did bring about a change for a while, but now the input lag has returned. This is likely a problem with the chipset or the operating system.
Kipperii
Post by Kipperii » 25 Jul 2026, 02:26
wasted42 wrote: ↑
24 Jul 2026, 21:53
I was similar. On the first day, things improved a lot; I could kill everyone. But then the problems slowly returned. Even so, overall, the USB Ethernet is still about 10% better than the onboard network card, and it's something worth investing in.
MontyTheAverage
Post by MontyTheAverage » 27 Jul 2026, 06:48
wasted42 wrote: ↑
24 Jul 2026, 21:53
Dread it, Run from it... Input lag/desync arrives the same.
MontyTheAverage
Post by MontyTheAverage » 27 Jul 2026, 06:53
Sandy wrote: ↑
24 Jul 2026, 22:41
wasted42 wrote: ↑
24 Jul 2026, 21:53
We are just spinning back to the same old threads. the input lag/desync issue exists on different chipsets, diffirent operating systems and also exists on consoles. Mouse/keyboard/controllers. Doesn't matter. At this point, look anywhere but hardware/software.
