X3D processor tip
Vocaleyes
X3D processor tip
Post by Vocaleyes » 02 Aug 2026, 09:59
Hey guys, if you have a *Dual CCD X3D chip, in Windows ALWAYS use the balanced power plan, not high performance.
Just in case some didn't know and turned it on by default.
cheers!
Vocaleyes
Re: X3D processor tip
Post by Vocaleyes » 02 Aug 2026, 15:56
kyube wrote:
02 Aug 2026, 10:02
Vocaleyes wrote:
02 Aug 2026, 09:59
Hey guys, if you have an X3D chip, in Windows ALWAYS use the balanced power plan, not high performance.
cheers!
www.google.com 😇😇😇😂
Post by RealNC » 02 Aug 2026, 16:04
All I can find is a reference to a Hardware Unboxed benchmark that compares balanced vs performance, but this video doesn't actually seem to exist? If it does, a search doesn't find it.
joseph_from_pilsen
Post by joseph_from_pilsen » 02 Aug 2026, 16:11
The trick with ballanced power plan being superior is however a bit outdated today. At 9800X3D there is almost no difference at all, especially with overclock applied. There were some changes and optimalizations in AGESA and scheduler made in time between so its no more so much straigtforward "better".
Hyote
Post by Hyote » 02 Aug 2026, 17:28
It is basic info that only dual CCD CPUs need the balanced power plan.
Vocaleyes
Post by Vocaleyes » 02 Aug 2026, 20:18
That's entirely my mistake. I should have specified "for dual CCD chips". For single CCDs like the 9800X3D, 7800X3D impact is minimal.
Hyote
Post by Hyote » 04 Aug 2026, 07:17
My 9850X3D feels the exact same than my 10850K did apart from the massive performance boost.
donger
Post by donger » 54 minutes ago
Source is AMD engineers i remember them talking about balanced power plan many many times...
