Permanent "lag" / delay since November 2020: Same issue across 3 different PCs, ISPs, and locations.
taupemouton
Hello, I really want to share my experience about the "lag" I suffered from around September or November 2020. I'll be really specific about what I mean by lag, because I see a lot of posts that are not describing enough what it feels like.
First, it all started with my old PC with these specs:
Asus vivobook pro 17
- i5-8250U
- 8go RAM
- OS: i was on Windows 10, and i swittched to Windows 11
It was really good to play with. The game I played the most was Minecraft on 1.16.2 on Skywars servers with new PvP. People were not as good as now at PvP, but sometimes you could play with good players. I played for months on servers and I had really good movement, aim, and it was easy to clutch… It was amazing. But one day, the game felt weird.
It was not even possible to win fights, or even clutches with blocks to not fall into the void. I thought it was a big skill issue, which is why I did not care at the time it happened, but it continued and became permanent. To be more specific about what it feels like, it's really, really hard (even against new players) to win 50/50 situations with skills.
The enemies always respond first. It became even more obvious with good players I played with before, because it was not even possible to hit them once. I thought it was something about my Wi-Fi, but the game was bad in single-player too (this is why I don't think it's about my ISP or my Wi-Fi). Because of that, I even had to change my mouse sensitivity because it seemed like it changed my aim. Then, in 2021, I switched to a new computer with these specs:
- i5-11400f
- 16go RAM ddr4 crucial ballistix
- rtx 2060
And absolutely nothing changed. I tried to make some tweaks on Windows, Wi-Fi, and BIOS. I tried CachyOS, and the game felt even worse. When I watch the gameplay of YouTubers on the servers I play on, I have the impression we do not play the same game. Some streamers are obviously not as good as me at PvP, but it feels like their game runs as it should, with no enemies always reacting first in every circumstance (even against noobs with zero game sense). I changed locations and ISPs, but nothing changed for me.
I reset Windows 11, but I haven't tried a clean reinstallation. The only common points between all of my computers are the OS (Windows), an Intel CPU, and the fact that I always plugged my Glorious Model O into the computers for the first time. I also never played my friend's computer.
I also did some research about the date when everything started to collapse, and the only thing I found was a Windows update made in November 2020. I can't go back in time to see what changed on my computer that day...
Ask me anything you want. Sorry for my English.
- i5-8250U
- 8go RAM
- i5-11400f
- rtx 2060
Terrykk
Re: Permanent "lag" / delay since November 2020: Same issue across 3 different PCs, ISPs, and locations.
Sorry but what kind of feedback do you expect from this type of thread? You have the same problem as everyone else here, just for Minecraft instead of CS2/Val/Ow. The symptoms are widely known, unfortunately the solution has not been found
Templar_Warden
just a little plug but dont forget apex legends, i mean obviously i know the issue exist on every game but its more or less about what people post specifically. Just a question but are the different locations you've tried still within the same state. Ive considered moving or taking a trip to test in a location like texas since there is many pros in the state and i know of no pro from the state i am. so my logic is that if people are good in Texas, surely I can be good there too. and by good i just mean without the "issue".
taupemouton
I am sorry, I thought people may have slightly different problemes than me, I wanted to share you this because I remember when it started to collapse. I thought it would be a good information to have...
I mean, it can't be something random that appears one day and stay permanent right? I thought using the date to try to know what caused that would be helpfull.
Templar_Warden
do not expect it to just fix itself eventually, i implore you to leave your state and get a whole new pc. those are the only two ways that people have said that theyve been able to fix there issues for thesmelves.taupemouton wrote: ↑11 Aug 2026, 03:41I am sorry, I thought people may have slightly different problemes than me, I wanted to share you this because I remember when it started to collapse. I thought it would be a good information to have...
taupemouton
Templar_Warden wrote: ↑12 Aug 2026, 01:35do not expect it to just fix itself eventually, i implore you to leave your state and get a whole new pc. those are the only two ways that people have said that theyve been able to fix there issues for thesmelves.taupemouton wrote: ↑11 Aug 2026, 03:41I am sorry, I thought people may have slightly different problemes than me, I wanted to share you this because I remember when it started to collapse. I thought it would be a good information to have...
Do you think i should entirely replace my computer or change only the CPU, Motherboard? I never tried ryzen CPUs.
Templar_Warden
I personally just went through the hassle of swapping from a 5800x3d to a 14600k, it did nothing. you can even try renting a pc at an internet cafe just as i did but most likely it wont do anything.taupemouton wrote: ↑12 Aug 2026, 05:02Templar_Warden wrote: ↑12 Aug 2026, 01:35do not expect it to just fix itself eventually, i implore you to leave your state and get a whole new pc. those are the only two ways that people have said that theyve been able to fix there issues for thesmelves.taupemouton wrote: ↑11 Aug 2026, 03:41I am sorry, I thought people may have slightly different problemes than me, I wanted to share you this because I remember when it started to collapse. I thought it would be a good information to have...
MontyTheAverage
Texas has mostly independent electrical grid than rest of America based on what I know. Maybe that is why.Templar_Warden wrote: ↑10 Aug 2026, 18:31just a little plug but dont forget apex legends, i mean obviously i know the issue exist on every game but its more or less about what people post specifically. Just a question but are the different locations you've tried still within the same state. Ive considered moving or taking a trip to test in a location like texas since there is many pros in the state and i know of no pro from the state i am. so my logic is that if people are good in Texas, surely I can be good there too. and by good i just mean without the "issue".
DudeBeFishing
Are these servers still on 1.16.2 or did they change to a newer version? The last version I had PvP combat on was 1.7.10. I remember dying to players who were too far away. Not sure if this game uses lag compensation or if it's client trusted.
