I think it also still uses the buildings ground wire if plugged in, not just the neutral, which could still carry some harmonics etc.MK92 wrote: ↑13 Aug 2026, 04:52The problem is literally fixed by battery, but you need to disconnect UPS from the wall which is pointless as it will turn off after ~5 minutes (as long as the UPS is still connected to the wall it will not work correctly as it would still use building's neutral wire as a reference, even if you set it to run on battery), and no in my case the problem is 100% fixed and not just 5% with a clean circuit and splitted tn-c into tn-c-s just for PC and monitor, it has been fine for 3 months already, now it works exactly the same as if i would have turned on oven or iron, or like it worked fine late at night, but now it works like that 24/7 regardless of other appliances turning on/off or time of the daySlender wrote: ↑12 Aug 2026, 16:43hah, then why isn't the problem fixed by the battery and the clean circuit? You did something that gave you a 5% improvement, which you mistook for a fix. But, it is ok, I really want people to move further and further away from the source of the problem.MK92 wrote: ↑10 Aug 2026, 03:26Not the first time at all, there are MANY people here - including myself - which fixed this by fixing broken neutral wiring, especially on old TN-C systems...we've been saying for so long that the problem is neutral impedance, neutral voltage drift and wrong neutral to ground potentials, and people still dream about some fictional "emi" and are buying emi meters...it's WIRING, not some fictional interference that jumps from PC to PC over air.
You did tn-c into tn-c-s just for pc and monitor, do you live in a house? Or you did separate neutral and ground just to the beaker panel in the apartment?
