Code: Select all
AMD KVM Mouse ProtocolModded settings - Absolute.
I definitely feel the difference between simple and absolute. Absolute feels much more sharper
Try it out maybe it will help you a little bit.
MOBO: Asrock b450m pro4-f (10.60 bios.)
Setup Question = AMD KVM Mouse Protocol
Help String = Swtich KVM Mouse Protocol between Absolut/Simple
Token =2B // Do NOT change this line
Offset =54
Width =01
Options =*[00]Absolute // Move "*" to the desired Option
[01]Simple
[03]Auto
