Technical analysis: Verifying uncompressed 540Hz/500Hz timings on DP 2.1 (ASUS PG27AQWP-W / AOC Q27G4KD)
HzAnalyst
Post by HzAnalyst » 16 Aug 2026, 03:53
Hi everyone,
I am currently in the process of building a high-end setup with an RTX 5080 (DP 2.1 UHBR20 support). Before I commit to purchasing a new display, I want to ensure my next monitor can handle QHD (2560x1440) 540Hz/500Hz, 10-bit RGB 4:4:4, completely uncompressed (DSC OFF).
I have performed a technical analysis based on the manufacturers' specifications, but I have encountered some mathematical discrepancies. Since I do not own these units yet, I am reaching out to the community for help in verifying their actual behavior.
Question 1: ASUS ROG Swift PG27AQWP-W (QHD 540Hz) – Actual Timing Verification
The official spec sheet for the PG27AQWP-W states a Maximum Horizontal Frequency of 850 kHz.
If we calculate the timing for QHD (2560x1440) at 540Hz:
  • If we optimize the Vertical Blanking (V-Blank) down to 134 lines, the Total Vertical Lines (V total) becomes 1574 lines (1440+134).
  • The required Horizontal Frequency (H freq) would be: 540Hz * 1574lines = 849.96kHz
This aligns perfectly with the monitor's physical limit of 850 kHz and utilizes roughly 89% of the DP 2.1 UHBR20 effective bandwidth, making uncompressed transmission theoretically possible.
My questions are:
Question 1-1. Does the PG27AQWP-W actually operate on this exact timing (V blank=134, H freq ≈ 850 kHz) when DSC is turned OFF in the OSD?
Question 1-2. I have heard that this monitor has a very strict "all-or-nothing" DP 2.1 fallback policy: if it doesn't establish a perfect UHBR20 link, it immediately drops to DP 1.4 (HBR3) instead of attempting UHBR13.5. Is this true, and does it cause handshake issues on RTX 50-series GPUs? If any owners could share their OSD 'System Information' or a CRU 'Detailed Resolution' report for 540Hz, it would be invaluable for my purchase decision.
Question 2: AOC Q27G4KD (QHD 500Hz) – Manual Typo Verification?
AOC's 1:1 support confirmed that the Q27G4KD supports QHD 500Hz, 10-bit, RGB 4:4:4 uncompressed via DP 2.1 UHBR20. However, the user manual lists the Maximum Horizontal Frequency as 510 kHz, which seems mathematically impossible for 500Hz.
Even if we hypothetically reduce the V-Blank to an absolute minimum of 1 line:
  • V total =1441 lines (1440+1)
  • The absolute minimum required Horizontal Frequency would be: 500 Hz×1441 lines=720.5 kHz
  • 720.5 kHz heavily exceeds the manual's stated limit of 510 kHz.
My question is:
Question 2-1. Is the 510 kHz limit in the AOC manual simply a typo (perhaps carried over from a 240Hz/360Hz model spec)? Does anyone currently using the Q27G4KD at 500Hz have data on the actual horizontal scanning frequency?
Question 2-2. Any insights, CRU screenshots, or real-world testing data from owners would be highly appreciated to help me make an informed purchase decision.
Thank you!
(Note: To clarify, all the technical calculations and timing analysis provided in my post are entirely my own work. I have personally analyzed the user manuals and calculated these frequencies based on display timing standards. I used an AI language model only to assist in refining and structuring my draft into professional English for this forum to ensure clarity for the community. The core engineering logic and mathematical validation are 100% mine.)
HzAnalyst
Re: Technical analysis: Verifying uncompressed 540Hz/500Hz timings on DP 2.1 (ASUS PG27AQWP-W / AOC Q27G4KD)
Post by HzAnalyst » 17 Aug 2026, 06:33
UPDATE (Partially Solved - Question 1-1)
Hey guys, just wanted to update this thread as I found some interesting info regarding my first question.
If you search Google for "TFT Central ASUS PG27AQWP-W review" and check the "DP 2.1 connectivity testing discrepancies" section, they actually confirm that running 1440p at 540Hz with 10-bit RGB 4:4:4 uncompressed (DSC OFF) works natively. Asus confirmed to them it is expected behavior due to tight panel parameters (low V-blank). Also, the bug in MCM101 firmware that auto-enabled DSC was officially patched in the MCM102 firmware released on Nov 17. So manual DSC-OFF at 540Hz is now fully working on DP 2.1.
However, my other two questions are still open and I would love to hear from owners:
1. Does the PG27AQWP-W actually drop straight to DP 1.4 (HBR3) if UHBR20 link training fails, completely skipping UHBR13.5 and UHBR10? Anyone experienced this handshake behavior?
2. Is the 510 kHz limit in the AOC Q27G4KD manual a typo? If anyone owns the Q27G4KD, could you share your actual Horizontal Frequency and V-blank values when running at 500Hz?
Any insights on these remaining points would be highly appreciated. Thanks!
Post by Chief Blur Buster » 21 Aug 2026, 01:48
These are pretty niche questions! Very Area51-like, so I'll post a link there.
I don't have these specific monitors in-house currently at the moment, but it does sound like a possible typo since the scanrate of 1440 * 540 = 777600 pixel rows per second = minimum of 777 KHz scan rate to do the advertised 540 Hz without the blankings!
And going down to 500 gives the 720 you mention.
Also:
The numbers you're throwing out suggests you're a videophile, and since I worked in the home theater industry:
Monitor behaviors are often esoteric black boxes on the wire these days. Keep in mind that cable bit depth is not necessarily panel bit depth. The curves (linear -> gamma/log/dolby/eotf/etc) means that effective bits will always be low at the OLED darks end (always worse than 10bit effectively when equalized over the curve instead of linear) and you'll still see graininess there regardless of the bits on the cable or the linearized bits, since your eyes adjust to the dark, and the bits can be dissapointingly limited. If you own any OLED TVs you are already aware of the compromise you've accepted. If not, then now you know.
Also, DSC-vs-nonDSC is a nonissue from a weak-links POV. I see the OLED dark problems more often than I remotely see any DSC image quality problems. 4:2:2 I see, but DSC, I don't notice. But alas, there's some crappy DSC implementations out there that appears to add unexpected lag, so YMMV. I wouldn't eliminate DSC as a videophile consideration as the videophile weak links tend to be elsewhere at the moment.
Now if you're doing scientific stuff (e.g. scientific displays) then that's another thing altogether.
I do apologize if it does not answer your questions. But I do add info on a "focussing on checkboxes" versus "focussing on end quality". Some OLEDs are just massively better than others.
Also -- the way the supply chain at the monitors often happen is separate companies often doing the panel versus the DP/HDMI chips versus the final product (brand on the monitor), scaler/TCON (which may be a third party such as MSTAR), and firmwares (another third party). No wonder mistakes can be made in the supply chain, but it does also explain why sometimes it's hard to answer questions quickly especially since it requires simultaneous slightly-uncommon convergence (skilled user + that user also has the monitor to verify + available time to answer question) especially if all the employees at the manufacturer are now working on a different model of the monitor and can't immediately verify the bug today for a rare call.
___
At the end of the day, these spec glitches are annoying, in a highly complex display manufacturing ecosystem:
These desktop screens are literally teraflop supercomputers all made commoditized into sub-$500 desktop screens (well, sub-$1K in this case), sold at thousand-quantities instead of million-quantities, and sometimes little details slip in cost-cutting and rapid resource reassignments in fast-paced Asia countries that sometimes prefer to focus on million-unit-selling TV models, or such.
Most of these screens cram a lot of compute in cheaper chips and hard-to-modify ASICs than a GPU. You can have hundreds or thousand math operations per subpixel per refresh cycle throughout the refreshing chain, including subpixel processing necessary for pixel driving, picture adjustments, overdrive algorithms, HDR, pixel refresh tracking algorithms, blended-zones for local dimming algorithms for LCDs, voltage compensation algorithms for the varying microwire lengths along the row-addressor grid to equalize pixel performance, to other bleep like that. Add all the math up, and it currently total many hundreds to low few thousand math calculations per subpixel per Hz. Multiply that by 2 billion subpixels per second of a 1440p540Hz display and you hit the trillions math ops per second built into a rapidly-commoditized desktop screen (at least the sale $300 240Hz OLED). That's not even including the math in DSC yet...
HzAnalyst
Post by HzAnalyst » 23 Aug 2026, 01:24
Wow, thanks for the amazing response Mark! Really appreciate the detailed breakdown. I totally agree that end-quality matters way more than just checking boxes on a spec sheet.
Since I'm still in the pre-purchase phase, those official specs (manual timings, horizontal scan limits, DP bandwidth) are literally the only clues I have. At the very least, I just want to verify whether these monitors can actually function as advertised according to their own official specs before dropping a grand on them.
Just trying to figure out if it's forced DSC or true native 10-bit uncompressed before buying. It has been a fun math puzzle to solve, even with the typos in the manuals. The supply chain stuff and the insane amount of real-time math the TCON/scalers perform that you explained really put things into perspective.
If my questions actually end up in the Area 51 vault, please let the aliens know I just want to know if my 540Hz monitor will run uncompressed!
Thanks again for sharing this to the Area 51 section. Much appreciated!
Dalek
Post by Dalek » 23 Aug 2026, 19:21
HzAnalyst wrote:
23 Aug 2026, 01:24
I recommend purchasing the monitor from a retailer that has a decent refund/return policy. That way if you do end up disappointed, at least you can return it easily.
