zedsdeadll
Post by zedsdeadll » 30 Aug 2026, 16:00
Shrimper wrote: ↑
30 Aug 2026, 09:20
Try setting the nvidia power management to "Prefer maximum performance" (requires reboot to take effect). It'll hopefully get fixed at future driver update.
I set "prefer maximum performance" for escapefromtarkov.exe. No blackouts after a 2-3 hour session. I'll add an update if the issue continues, thanks for the advice!
mawi
Post by mawi » 31 Aug 2026, 02:53
zedsdeadll wrote: ↑
29 Aug 2026, 22:01
Hey guys - I just purchased the XG27AQNGV and the screen goes black for 2 to 3 seconds then recovers. It's completely random, but I've been able to reproduce it mostly in the Escape from Tarkov menu. My second monitor never does it. Nothing shows in Event Viewer.
Yes... Nvidia is already looking into this. Its a common problem of RTX30/40 cards with 360 Hz wqhd monitors. I have also read about similar problems with UHD 240 Hz screens. As mentioned Nvidia already stated that changing to maximum performance mode should get rid of random ingame black screens.
But the alt-tab black screens will remain, this seems to be a different issue.
If you reduce your monitor frequency to 240 Hz (which still looks amazing with pulsar) there will be less and shorter black screens. If you want to get rid of them completely you have to switch to single tile mode via registry.
This will also remove 360 Hz mode. Then your monitor will behave perfectly snappy, no more black screens at all.
I ran my 4070 for several months like this and it worked great. In the end I upgraded to RTX50 and all black screen problems are gone in normal operation with 360 Hz.
I hope they will get this under control. So many 360 Hz users out there which suffer from these handshake problems. Not just pulsar users.
Damnsonny
Post by Damnsonny » 31 Aug 2026, 06:58
zedsdeadll wrote: ↑
29 Aug 2026, 22:01
3080ti, DP 1.4 with DSC, firmware V1.1.8
I've tried:
  • Multiple DP cables. Happens on both a VESA-certified DP80 1m cable and the cable that came with the monitor.
  • Swapping GPU ports
  • Pulsar on/off
  • G-Sync scope set to windowed plus fullscreen and fullscreen only
  • 10 bpc vs 8 bpc, stock OSD settings
Anyone else seeing this, or have any ideas on what to try next?
I have this exact same issue. It happens randomly in different games. I have 4 monitors, doesnt happen on other monitors. 4080 Super. One game where it constantly happens is A.W.O.L on steam.
faro
Post by faro » 31 Aug 2026, 09:49
zedsdeadll wrote: ↑
29 Aug 2026, 22:01
I've tried:
  • Pulsar on/off
I'm having exactly the same issue with my RTX 3080. Random black screens for a couple of seconds, while my second monitor remains perfectly fine.
mawi wrote: ↑
31 Aug 2026, 02:53
Thanks a lot for all this information! This is really helpful, especially knowing that 240 Hz / single tile mode can work around the issue and that it seems to disappear with RTX 50-series cards.
MSIfanboy
Post by MSIfanboy » 31 Aug 2026, 16:52
Why does this monitor have the old OSD software, it's basically a copy of pg248qp and pg27aqn but with pulsar and 60hz ulmb2 option
I have 3 other Asus monitors with the newer software, and 2 were cheaper
Another annoyance of this monitor
tsarri
Post by tsarri » 31 Aug 2026, 22:10
Really hope they can fix the image retention problems eventually as well. Not too sure how common that issue is but I know of at least one other person that has mentioned it.
MSIfanboy
Post by MSIfanboy » 01 Sep 2026, 02:28
only image retention i noticed is with the ufo test, the white lines, same as my other ips lcds, but never on any TN monitor i own
tsarri
Post by tsarri » 01 Sep 2026, 11:27
MSIfanboy wrote: ↑
01 Sep 2026, 02:28
It's really only noticeable on grey background for me and its almost exclusively white text and fine lines. Doesn't last very long but its always there when leaving static content for too long with pulsar enabled. Not the worse issue but still.
passballtotucker
Post by passballtotucker » 01 Sep 2026, 13:42
tsarri wrote: ↑
31 Aug 2026, 22:10
The image retention is terrible. This can't be used as a crt replacement unless you only play 240p games. If you try to play 480i games with retrotink's crt simulation it will have image retention in less than a minute. Apparently this is common with IPS panels. Maybe they could have the next pulsar on a good VA panel.
edgintheledge
Post by edgintheledge » 02 Sep 2026, 00:00
MSIfanboy wrote: ↑
31 Aug 2026, 16:52
If it hasn't been mentioned already, the OSD lacking a VRR toggle is annoying for me. My much cheaper VG27AQM1A has a toggle that you can use without having to open NVCP every time.
Bonus annoyance points on Linux, as Nvidia drivers on Wayland can only disable/ignore VRR for ULMB by using a nvidia-modeset parameter (Meaning a reboot is required every time you want to change it 💀💀💀). A simple OSD toggle bypasses this issue.
