Re: My experience with “the lag” and temporary fixes
astroasis
Post by astroasis » 19 Aug 2026, 16:35
perpe2334 wrote:
19 Aug 2026, 16:28
MK92 wrote:
19 Aug 2026, 16:27
Just look at your first post at this forum viewtopic.php?p=120559#p120559, full schizo OCD mode where the dude thinks that closing bathroom door is causing his input lag, and location of PC tower, and location of windows...either full troll or full schizo, anyone with an IQ of over 50 knows that body cannot impact microproccesing inside a sealed faraday cage, go at some professional top tier event then and ask if you can play at pros computers so you can demonstrate that your body destroys the PC and cause pro players to play like shit...full schizo
I don't care what you think, bro. If you've fixed the issue, prove it; otherwise, you're just totally delusional.
And for some reason he's posting here instead of enjoying a desync free life lol, I for sure wouldn't be here if my 1440p 240hz actually looked like it
perpe2334
Post by perpe2334 » 19 Aug 2026, 17:13
For the last 10 years of my life , I saw such a significant improvement with this topic. It was actually pretty good for about a month. I even shared gameplay on Discord and gained some Elo. I thought I had finally found something significant, and it lasted for a long time—about a month.
Right now, the window is still open 24/7, and I’m sitting next to it. The monitor and phone screens are still sharp, but the input lag and mouse issues have come back. I also still have my allergy problem; that hasn’t gone away, so I can’t say anything for certain.
If you solved it so easily, prove it, or go on fooling yourself. Most people tried more than one place, and sooner or later the problem comes back. There’s nothing else that could affect it besides your body. You’ve probably already tried another account and another phone anyway—there’s no other explanation for this.
Since you’re supposedly so knowledgeable, explain this too: how can the electrical system in your house affect the performance of a laptop that’s running on battery? Or why is it that even if most people buy a brand-new phone, after a certain amount of time the phone starts overheating more than it should, and the battery drains faster compared to people using the same model?
You’re just someone who’s fooling yourself. Admit it. Yes, I use AI because my English isn’t very good, but I understand what is being written.
MK92
Post by MK92 » 20 Aug 2026, 03:09
perpe2334 wrote:
19 Aug 2026, 17:13
Cool, so you can EASILY prove this and record it...record the monitor to see how sharp it is, then close the window and record again, if this bullshit placebo is the cause you can immediately prove it by just opening/closing window, it should be instant difference.
perpe2334 wrote:
19 Aug 2026, 17:13
How the hell does this means its your body doing stuff to electronics, do you have the same problem in BIOS, desktop, web browsing, youtube etc. etc.? No, because you have problem only in a freaking valorant? You have bad connection and routing from your place, after some time the traffic might get congested so its causing desync from the main server, simple as fuck, this is why people always report how it works fine for several minutes before its going bad.
perpe2334 wrote:
19 Aug 2026, 17:13
Lol, overheating of the phone and battery draining faster, and also possible slower charging speed as well, is LITERALLY caused by constantly charging it at bad electrical installation which destroys the battery over time, this is a textbook voltage neutral drift due to impedance, harmonics and stuff...before I fixed my wiring, my phone was charging so slowly, disconnected several times, overheated and never even charged to 100%.
perpe2334
Post by perpe2334 » 20 Aug 2026, 07:15
MK92 wrote:
20 Aug 2026, 03:09
perpe2334 wrote:
19 Aug 2026, 17:13
perpe2334 wrote:
19 Aug 2026, 17:13
perpe2334 wrote:
19 Aug 2026, 17:13
First of all, I’m not going to keep arguing with you about this. If I’m going to act like an adult, then the first thing you need to do is tell me that you’ve actually solved the problem, and until you can prove that, there’s nothing for us to discuss.
The human body doesn’t work like an on/off switch. Maybe you should look up some actual research involving people and electronics. For example, there are some interesting things to read here: https://www.researchgate.net/publicatio ... _Field_MRI
I’m definitely not claiming that this is what’s causing our specific problem, but the human body absolutely can affect electronics. Whether you believe that or not is irrelevant to me.
I never told you anything about phone battery health. I tested this when everything was in perfect condition, and I also tested it with other people using the same setup in the same house, etc. But none of that matters because it was years ago and I don’t have the data anymore, and I’m not going to waste my time digging it all up.
And what’s with immediately judging something without understanding anything about it? How do you know whether I tested it without a BIOS, or without a modem, or under different conditions? You’re just making assumptions.
And then you’re apparently implying that I play Valorant all the time or something. I didn’t play Valorant at all outside of testing. But again, that’s not even the point. You’re just making random assumptions in your head and trying to belittle me.
Let me tell you something: I don’t think you actually have input lag. I think you got absolutely destroyed by some 15-year-old kid playing Valorant, and your ego just can’t handle it. Your brain and hands stopped keeping up, you got embarrassed by kids, and now you’ve started blaming electricity for it.
So here’s what I’m saying: if your IQ is above 50, stand behind what you wrote and prove it. Then I’ll take the information you gave me, call an electrician, fix the problem, and maybe I’ll finally start playing Valorant and having some fun. :D
JerryKS
Post by JerryKS » 24 Aug 2026, 14:16
I have one hypothesis.. Like you said maybe it's our body causing the input lag.. Then Maybe it's possible that there is some static electricity exchange when we touch our controllers, mouse, keyboard. I have a wired keyboard and a wireless mouse. Maybe the system doesn't get effected instead it's US who gets effected by this static electricity exchange and then our brain's have this thing we perceive as input lag.. Ik it sounds stupid and crazy but just a thought. To test this the only thing I can think of is Isolating our hands and whatever that's getting in contact with the system with something that can block complete electricity as well as shielding our hands to stop emmiting emi completely. If you google it You can find Human body does emit EMI even though it's very weak and low. But maybe its just enough to cause this weird input lag somehow.
SweatHatesMe?
Post by SweatHatesMe? » 02 Sep 2026, 15:03
JerryKS wrote:
24 Aug 2026, 14:16
very unlikely, its an electric phenomenon YESSS. If it was some sort of EMI this would leak to the mobo through and crash the device, wouldnt just cause input lag or desync. Also EMI doesnt prove why using gloves or some type of shielding reduces the input lag for some of us, EMI just would go through the shielding without a problem, but again some elctro-phyisic phenomenon is going on which produces the input lag/desync.
MK92
Post by MK92 » 03 Sep 2026, 03:07
SweatHatesMe? wrote:
02 Sep 2026, 15:03
And who told you that, some kind of dumb AI chatbot? If you have a PC from 1990 then yes it would crash, but any newer PC would cause error-correction to keep device turned on = delays in processing.
JerryKS
Post by JerryKS » 03 Sep 2026, 03:15
MK92 wrote:
03 Sep 2026, 03:07
02 Sep 2026, 15:03
I agree with this guy. The newer PC's won't just crash straight away unless the errors are way too much but instead it would do error correction and retransmit the data and this retransmission of data again and again can cause small input lag..
kimchi man
Post by kimchi man » 04 Sep 2026, 03:46
I’m skeptical of the idea that the problem is caused by the human body or by sweat produced by the body affecting the computer.
I have actually played games in PC cafés where the environment seemed to be in the “perfect” state we’re talking about. The experience was consistently perfect every time.
One thing worth pointing out is that PC cafés operate 24 hours a day, continuously, for years. They have a huge number of people coming and going, and the equipment is constantly being touched by different people. Sweat, dead skin cells, and even moisture from people’s mouths can come into contact not only with the keyboards and mice, but also with the monitors and other equipment.
Yet despite all of that, those PCs remained in perfect condition. There was no sign of the issue we’re discussing.
For that reason, I’m skeptical that the human body itself is having a significant effect on the computer and causing this problem.
There’s another point I’d like to make. In an attempt to find common characteristics among environments where the problem does **not** occur, I visited a large number of PC cafés across the country. I’ve been to more than 20, roughly speaking, and only two of them provided what I would consider a truly perfect experience.
This may explain why the problem can persist even after moving homes many times. If roughly 90% of environments have whatever underlying condition is causing the problem, while only around 10% are free of it, then even after moving ten times, there is still a high probability that you will end up in an environment where the problem exists.
In other words, the problem may be far more widespread than we realize, while only a small minority of people are fortunate enough to play games in an environment that allows their PC to perform at 100% of its potential.
That is why I don’t think moving to another place is necessarily a reliable way to solve the problem. If the underlying issue is widespread, you can move repeatedly and still keep ending up in an affected environment.
MaleGigolo
Post by MaleGigolo » 05 Sep 2026, 13:18
kimchi man wrote:
04 Sep 2026, 03:46
If you play competitive video games you would know that this problem is not widespread. When i spectate players in OW2, CS2, Valorant etc their limiting skill is their game knowledge, positioning, etc and not their aim in most cases. If in rare cases they have potato aim it's clear they are aiming at the floor or are in general just bad players. I was just playing against Plat Hanzo in OW2 and it was very obvious why he was Plat... poor positioning, horrible game sense, tilting plays, etc but his aim was cracked and in no way could someone with this problem hit those shots that consistently. It happens every other game too. I'm suprised at how cracked most people are at games today... I see kids in Rocket League doing triple resets in low Champ, which is physically impossible if you have this problem. Just watching random guides on Youtube and paying attention to the way their cursor behaves and how fast they navigate around on their PC is amazing to me because if you have this problem you know that just navigating your OS/Browser is a struggle because of how delayed and inaccurate the mouse is. Best feeling to describe it is as if your mouse had a brain of its own and was constantly slipping on the ice and changing it's DPI randomly.
Also this problem not being EMF/Power related does not mean it is caused by our bodies. Google what anomaly means... It could be millions of different things.
