ASUS VG248QE Lightboost 100Hz color profile?
jonny30bass
Hello, I just got this ASUS VG248QE monitor and I was wondering if anyone has a calibrated Lightboost 100Hz icm/icc profile for this monitor. I think all of the Lightboost color profiles that I found are for 120Hz, but my gpu can't handle 120 fps in my games. Thank you.
Re: ASUS VG248QE Lightboost 100Hz color profile?
The color difference between 100/110/120 Hz is negligible so you can use the 120Hz profile.
jonny30bass
Alright. Thanks for the info!Razorless wrote:The color difference between 100/110/120 Hz is negligible so you can use the 120Hz profile.
