Improved my hitreg with Router Transmission Power
Cosmostraveler
Post by Cosmostraveler » 09 Oct 2026, 03:44
The change and result is very simple to setup and see.
In my case, I had 3 options: "Low;Middle;High". On some routers it will appear as %s.
Default was High, for both 2.4ghz and 5ghz.
I tested them on all variations, and each combination had different effect towards hitreg and recoil.
You can quickly Google the suggested settings for 1 home router/minimal devices, or 2 routers and various devices.
However, I'd suggest u test this in real time while having the game open.
Let me know what you find out.
spkii
Re: Improved my hitreg with Router Transmission Power
Post by spkii » 09 Oct 2026, 04:27
Cosmostraveler wrote: ↑
09 Oct 2026, 03:44
Hitreg only improved or desync and Ferrari Peeks too?
darkbebe
Post by darkbebe » 09 Oct 2026, 04:38
so you're playing on wifi?
ablemor
Post by ablemor » 09 Oct 2026, 06:12
You do know, of course, that this can be modified not only on the router but also in the Windows driver settings, right?
