TIME TO SEE 1ST ENEMY PIXEL RESEARCH + lookin for 24" FHD 440+HZ W/ BFI/BLS AT MAX HZ MON
DarkLord1337
Post by DarkLord1337 » 14 Oct 2026, 14:49
first paragraph is me venting/crying u can skip it if u dont care xD
im crying all day on night and breaking my table my secret chinese oem 540hz fhd 24" ips with bfi at 540hz monitor is broken its as if its getting tired after few hours of work and turns black with backlight on so the pixels are actively emitting black light kinda and i osd not working ofc i turn it off and on then it works for few seconds then again same. i changed adapter same thing so some internal problem but i cant fix it myself and ppl who can fix it r not in my town..
and today after waking up i was playing first cs match of the day and in the middle of the match it started doing that idk it never happened before usually it will work for at least 2-4 hours.. so its the last drop im tired i dont have time to wait till ill get new one for almost (need to pay for delivery) free so i set out to find new one and to my surprise i couldnt easily find such monitor still in the end of 2026! even tho i bought my monitor like 1.5 years ago! has the technology not improved or what.
im searching now for full hd 23-25 inches 440hz+ monitor with bfi/bls at max hz with ips panel. does it exist?
and also (but first full hd is more important for my fps kinda rn) looking for qhd (as small as possible) with 390hz or higher with bfi/bls at max hz with ips panel.
(i know there is lg 1khz monitor but its hard to buy and my 4070 ti super doesnt support 1000hz coz its more than 1350mhz on single head and its kinda expensive, ill buy it but in future when upgrading pc, not now)
(not looking for trash tn with grey colors and somehow it changes color in the part of the monitor above my eyes like from purple to black idk why on all tn i tested and colors r horrible so only need ips (since oled doesnt have bfi at max hz if its possible id buy it too like same specs but oled))
attachments are big idk if its only for me or for everyone but someone pls do tell me how to hide them so that u can press + and open them if u want, im not sure..
DarkLord1337
Re: lookin for 24" FHD 440+HZ W/ BFI/BLS AT MAX HZ MON
Post by DarkLord1337 » 14 Oct 2026, 18:57
also i dont wanna buy 360hz like i said but from knowledge perspective which one will be more clear in motion
XG27AQNGV qhd 360hz with pulsar or lg 1000hz ips with bfi on?
also i was researching Chinese monitors and found very promising affordable monitor 24.5" IPS QHD 420HZ W/BFI (ill attach specs pic)
but then looking for proof that bfi works at 420hz for it ive found this reddit comment about it:
No_University_7654
OP
4mo ago
Okay, so it finally came after a month and heres my review. Colors were vivid and not oversaturated maybe due to qd film and theres no grayish, yellow or other color tint (or i can be used to warmer color so check it on your own), the brightness is really good and even on 0% brightness in dark room its usable and you can see every detail on a screen, contrast and dimming zones work algorithm is also very good, i saw no halos or dimmer white text on black background, motion clarity with dyds fps mode and 420 hz overclock is amazing, but 280 hz tandem woled still had slight edge in motion clarity due to pixel response times, stand is also very good, you can tilt and rotate it on x,y axis and lift it up or down but i used it on arm so stand was used just for check. there was no high pitch coil whine from psu block nor monitor while working or standby and my eyes was not strained at all while i used it after adjusting settings on full brightness with level 3 dyds which could potentially be agressive for eye strain. I think its really good all around monitor for fps/story games, work and watching movies if you prefer 24 inch monitors.
so then i asked him then
what's best for motion clarity im looking for 23-25" monior with fhd/qhd res. which oled in motion clarity is best? and has highest hz too. size 26.5 or smaller actually but better 23-25
but i mean motion clarity is good but i also wanna see enemy faster coming out of corner. so lets think:
same refresh rate but one monitor has higher res then it wins coz u can see enemy faster
same rr but one mon has better motion clarity well same speed but better for flicks ok
but if the res is different then what? fullhd monitor with X refresh rate is equal to what refresh rate QHD monitor in terms of seeing enemy coming out of the corner. coz i was thinking if in full hd small part of enemy less than pixel will show i won't see it on fhd but maybe will see it on qhd or 4k and then it means 4k is better but ai said that partial pixel also can be changed when enemy is partially occupying it.
so i asked it what part of pixel enemy need to occupy in order to change pixel even partially and it said this (i will post in next msg)
[spoiler]
specs chinese monitor.png (62.88 KiB) Viewed 98 times
display structure for chinese monitor.png (74.18 KiB) Viewed 98 times
top motion clarity monitors.png (84.21 KiB) Viewed 98 times
[/spoiler]
DarkLord1337
Re: TIME TO SEE ENEMY RESEARCH + lookin for 24" FHD 440+HZ W/ BFI/BLS AT MAX HZ MON
Post by DarkLord1337 » 14 Oct 2026, 19:00
idk how to hide attachments maybe there r too big and uncomfortable to read. if u have any advice let me know im new here.
about pixels and corners.png (222.58 KiB) Viewed 97 times
ranking oled vs 420hz.png (132.36 KiB) Viewed 97 times
ranking oled vs 420hz pixel around corner.png (110.05 KiB) Viewed 97 times
DarkLord1337
so this is what it said about parts of pixels
and yes im aware it doesnt matter so much but once i start researching and thinking about any interesting to me topic i cant stop till i find out exactly how it works and whats the best way to use that info (like optimize ur settings for this for example in this case)
pixel parts to change pixel 1.png (202.2 KiB) Viewed 97 times
pixel parts to change pixel 2.png (75.34 KiB) Viewed 97 times
DarkLord1337
Re: TIME TO SEE 1ST ENEMY PIXEL RESEARCH + lookin for 24" FHD 440+HZ W/ BFI/BLS AT MAX HZ MON
Post by DarkLord1337 » 14 Oct 2026, 19:42
more about pixel changes
pixels and corner with bfi and without msa.png (160.1 KiB) Viewed 83 times
sampling explanation 1.png (171.37 KiB) Viewed 83 times
sampling and full pixel change.png (193.19 KiB) Viewed 83 times
DarkLord1337
Post by DarkLord1337 » 14 Oct 2026, 19:44
well yeah thats what ive been using anyway in valorant and other games aa x4 and 16x af because it gives me smooth picture, more crispy feeling of enemy texture i compared it myself with screenshots in valorant for example so for me its better. so i guess its what u want faster partial change of pixel color or faster full change of pixel color. for the price for me 420hz is better and i always wanted to try higher than fhd monitor at 24.5 inches, not 27, so ill try that!
partial pixel change final and 420hz settings.png (211.44 KiB) Viewed 83 times
about pixels and corners 2.png (163.84 KiB) Viewed 83 times
DarkLord1337
Post by DarkLord1337 » 14 Oct 2026, 20:11
found ufo test for it in some review https://imgur.com/a/vGGmsLw
here is the link u can check video in 4k
so it seems ultra low latency mode level 3 is the best for their bfi. looks very good tbh.
the only downside ig is that its not glossy but u cant find such monitor that is glossy i think, i tried.
