You forgot the most important fact, it's almost 1/2 the price of the 86X+
Majority of Zowie products are sadly too overpriced to ever warrant their purchase over equivalent panel models from other vendors...
True. I suppose like many things, you're paying for the name, not the hardware.
It's 10 LED zones, see the snip I put months back. On my unit, I use overdrive 14 because at 15 I can start to notice overshoot on certain colours.Ali wrote: ↑14 Oct 2026, 12:23I ordered the AOC CS24A 610Hz monitor instead of the ZOWIE XL2586X for one reason only: motion blur reduction technology.
The ZOWIE XL2586X+ and other ZOWIE monitors with DyAc 2 use 10-zone LED backlight strips to simulate CRT-like motion clarity, whereas the AOC CS24A 610Hz with MBR+ uses 20 individual LED backlight strips. This is why I believe the AOC's MBR+ implementation can deliver better motion clarity with less eye strain than DyAc 2.
On top of that, even at its highest MBR+ settings, the AOC reportedly maintains over 300 nits of full-screen brightness. Another major advantage is that you can independently tune the overdrive and MBR+ settings simultaneously, giving you more flexibility to optimize motion clarity and response times.
According to multiple reviewers, Overdrive 15 and MBR+ 20 are the best settings. For me, these features make the AOC CS24A a more interesting choice than the ZOWIE XL2586X+.
I’m currently using this AOC 610Hz CS2 monitor, and I also have a BenQ XL2586X+ on hand. Overall, I find that the AOC has a less grainy screen coating than the BenQ, along with slightly better sharpness. The colors are also undeniably superior especially for daily use and the brightness seems better as well. That said, I think Zowie still holds the edge when it comes to motion clarity; at a speed of 1920 in the UFO test, it’s noticeably sharper, though in real-world usage, the difference is imperceptible. I’m currently running it with Overdrive set to 13 and MBR at 15—a configuration I’ve found offers the best balance of high brightness and solid motion clarity. For the price, this monitor is a better deal, though I do think it should offer an option to disable DSC. Changing the subject i have a question, though: when using HDMI 2.1, the Nvidia Control Panel only shows 144Hz under the "PC" section; to get anything higher, I have to create a custom resolution. Also, I can’t seem to use 1728x1080 over HDMI—it only works via DisplayPort. Do all the refresh rate options (like 240Hz, 480Hz, 540Hz, etc.) show up for you when using HDMI? I’ve seen them appear normally in some reviews.Ali wrote: ↑14 Oct 2026, 12:23I ordered the AOC CS24A 610Hz monitor instead of the ZOWIE XL2586X for one reason only: motion blur reduction technology.
You had the 540Hz Acer, right? What did you think of this AOC model in comparison?petight wrote: ↑15 Oct 2026, 09:20It's 10 LED zones, see the snip I put months back. On my unit, I use overdrive 14 because at 15 I can start to notice overshoot on certain colours.Ali wrote: ↑14 Oct 2026, 12:23I ordered the AOC CS24A 610Hz monitor instead of the ZOWIE XL2586X for one reason only: motion blur reduction technology.
Yeah, it’s also significantly cheaper than the Zowie XL2586X+.
According to AOC, the CS24A 610Hz monitor's MBR+ technology uses 20 LED zones, which is one of the main reasons I chose it over the ZOWIE XL2586X+ with DyAc 2.petight wrote: ↑15 Oct 2026, 09:20It's 10 LED zones, see the snip I put months back. On my unit, I use overdrive 14 because at 15 I can start to notice overshoot on certain colours.Ali wrote: ↑14 Oct 2026, 12:23I ordered the AOC CS24A 610Hz monitor instead of the ZOWIE XL2586X for one reason only: motion blur reduction technology.
Have you tested the AOC CS24A 610Hz with overdrive set to 15 and MBR+ set to 20 against the ZOWIE XL2586X+ with DyAc 2 Premium? In the 1920 FPS blur test, does the ZOWIE look clearer than the AOC?Lucasre5 wrote: ↑15 Oct 2026, 10:31I’m currently using this AOC 610Hz CS2 monitor, and I also have a BenQ XL2586X+ on hand. Overall, I find that the AOC has a less grainy screen coating than the BenQ, along with slightly better sharpness. The colors are also undeniably superior especially for daily use and the brightness seems better as well. That said, I think Zowie still holds the edge when it comes to motion clarity; at a speed of 1920 in the UFO test, it’s noticeably sharper, though in real-world usage, the difference is imperceptible. I’m currently running it with Overdrive set to 13 and MBR at 15—a configuration I’ve found offers the best balance of high brightness and solid motion clarity. For the price, this monitor is a better deal, though I do think it should offer an option to disable DSC. Changing the subject i have a question, though: when using HDMI 2.1, the Nvidia Control Panel only shows 144Hz under the "PC" section; to get anything higher, I have to create a custom resolution. Also, I can’t seem to use 1728x1080 over HDMI—it only works via DisplayPort. Do all the refresh rate options (like 240Hz, 480Hz, 540Hz, etc.) show up for you when using HDMI? I’ve seen them appear normally in some reviews.Ali wrote: ↑14 Oct 2026, 12:23I ordered the AOC CS24A 610Hz monitor instead of the ZOWIE XL2586X for one reason only: motion blur reduction technology.
Yes, I tested it. Comparing MBR at 20 with DyAc at the "Premium" setting, DyAc is sharper—though the difference is slight. As I mentioned, it’s only noticeable during the "UFO test"; in real-world usage, it’s completely imperceptible. DyAc at the "Premium" setting also offers slightly higher brightness than MBR at 20. Setting MBR to 15 or 16 results in much higher brightness—significantly brighter than DyAc—with only a minimal difference compared to setting 20, so I’d recommend using one of those two levels. Another point to consider is that the Zowie monitor, whether DyAc is enabled or not, produces far more image artifacts than the AOC, and they are much more noticeable. In my view, the AOC strikes a better balance between motion clarity and overshoot/inversion artifacts. It’s also worth noting that the BenQ has better contrast; however, for competitive gaming, I find that the AOC provides a clearer image, making things easier to see. To be clear, in actual use, I don’t perceive any performance difference at 500/600Hz whether strobing is on or off—it’s just an extra feature, and it does, in fact, introduce additional input lag.Ali wrote: ↑Yesterday, 07:02Have you tested the AOC CS24A 610Hz with overdrive set to 15 and MBR+ set to 20 against the ZOWIE XL2586X+ with DyAc 2 Premium? In the 1920 FPS blur test, does the ZOWIE look clearer than the AOC?Lucasre5 wrote: ↑15 Oct 2026, 10:31I’m currently using this AOC 610Hz CS2 monitor, and I also have a BenQ XL2586X+ on hand. Overall, I find that the AOC has a less grainy screen coating than the BenQ, along with slightly better sharpness. The colors are also undeniably superior especially for daily use and the brightness seems better as well. That said, I think Zowie still holds the edge when it comes to motion clarity; at a speed of 1920 in the UFO test, it’s noticeably sharper, though in real-world usage, the difference is imperceptible. I’m currently running it with Overdrive set to 13 and MBR at 15—a configuration I’ve found offers the best balance of high brightness and solid motion clarity. For the price, this monitor is a better deal, though I do think it should offer an option to disable DSC. Changing the subject i have a question, though: when using HDMI 2.1, the Nvidia Control Panel only shows 144Hz under the "PC" section; to get anything higher, I have to create a custom resolution. Also, I can’t seem to use 1728x1080 over HDMI—it only works via DisplayPort. Do all the refresh rate options (like 240Hz, 480Hz, 540Hz, etc.) show up for you when using HDMI? I’ve seen them appear normally in some reviews.Ali wrote: ↑14 Oct 2026, 12:23I ordered the AOC CS24A 610Hz monitor instead of the ZOWIE XL2586X for one reason only: motion blur reduction technology.
My AOC CS24A 610Hz is still being held by customs, so I’ll most likely get my hands on it next week. I can’t wait to test it myself!
Lucasre5 wrote: ↑Today, 10:39Yes, I tested it. Comparing MBR at 20 with DyAc at the "Premium" setting, DyAc is sharper—though the difference is slight. As I mentioned, it’s only noticeable during the "UFO test"; in real-world usage, it’s completely imperceptible. DyAc at the "Premium" setting also offers slightly higher brightness than MBR at 20. Setting MBR to 15 or 16 results in much higher brightness—significantly brighter than DyAc—with only a minimal difference compared to setting 20, so I’d recommend using one of those two levels. Another point to consider is that the Zowie monitor, whether DyAc is enabled or not, produces far more image artifacts than the AOC, and they are much more noticeable. In my view, the AOC strikes a better balance between motion clarity and overshoot/inversion artifacts. It’s also worth noting that the BenQ has better contrast; however, for competitive gaming, I find that the AOC provides a clearer image, making things easier to see. To be clear, in actual use, I don’t perceive any performance difference at 500/600Hz whether strobing is on or off—it’s just an extra feature, and it does, in fact, introduce additional input lag.Ali wrote: ↑Yesterday, 07:02Have you tested the AOC CS24A 610Hz with overdrive set to 15 and MBR+ set to 20 against the ZOWIE XL2586X+ with DyAc 2 Premium? In the 1920 FPS blur test, does the ZOWIE look clearer than the AOC?Lucasre5 wrote: ↑15 Oct 2026, 10:31I’m currently using this AOC 610Hz CS2 monitor, and I also have a BenQ XL2586X+ on hand. Overall, I find that the AOC has a less grainy screen coating than the BenQ, along with slightly better sharpness. The colors are also undeniably superior especially for daily use and the brightness seems better as well. That said, I think Zowie still holds the edge when it comes to motion clarity; at a speed of 1920 in the UFO test, it’s noticeably sharper, though in real-world usage, the difference is imperceptible. I’m currently running it with Overdrive set to 13 and MBR at 15—a configuration I’ve found offers the best balance of high brightness and solid motion clarity. For the price, this monitor is a better deal, though I do think it should offer an option to disable DSC. Changing the subject i have a question, though: when using HDMI 2.1, the Nvidia Control Panel only shows 144Hz under the "PC" section; to get anything higher, I have to create a custom resolution. Also, I can’t seem to use 1728x1080 over HDMI—it only works via DisplayPort. Do all the refresh rate options (like 240Hz, 480Hz, 540Hz, etc.) show up for you when using HDMI? I’ve seen them appear normally in some reviews.Ali wrote: ↑14 Oct 2026, 12:23I ordered the AOC CS24A 610Hz monitor instead of the ZOWIE XL2586X for one reason only: motion blur reduction technology.
