https://github.com/artzox/BFI-Presenter
Lets talk about this new tool, which allows you to have multiple black frame insertions in different areas inside a single rendered frame.
BFI Presenter
- nuninho1980
Re: BFI Presenter
Welcome you.
But if you want to watch 50 or 60 fps encrypter TV by DRM on 100 or 120Hz (un)strobing of monitor, the main disadvantage is any unabled BFI software (eg: your name, ShaderBeam,...). But to solve this disadvantage, you need to buy any new G-SYNC Pulsar monitor for work 50Hz-strobe*. Or ViewSonic XG2431 24" or XG270 27" monitor for work 60Hz-strobe.
* - how to enable strobe for 50Hz: https://www.nvidia.com/en-us/geforce/fo ... r/3624899/
Best regards.
Best regards.
RAM: 2x16GB DDR4@3600MHz
MB: MSI PRO Z690-A DDR4
GPU: Zotac RTX 4090 non-OC <3
HDD: SATA 1TB
PSU: AEROCOOL 1kW 80+ Gold
Disly: ACER Predator XB273U F5 !NEW!
HDD: SATA 1TB
