I think @kyube that at best we could only see maybe 1 "extreme" pulsar mode (if at all) given it would probably be very intensive for them to implement multiple pulsar levels given they really refused giving us a "variable pulse width" when we asked. I hope they at least give us a pulsar "extreme" mode with 1/2 the duty cycle across the board (thus half brightness) for better clarity and less brightness (I think it's too bright). Want to re-iterate, still enjoying my pulsar monitor as is! Wish they'd crank out some more stable drivers and give us a pulsar "extreme" mode as a "nice to have"
liquidshadowfox
Recent nvidia drivers after 610.88 has been horrible for me with terrible stutters and frame pacing issues with Gsync + vsync + low latency mode = on which ruins pulsar. Hopefully nvidia fixes it soon because I can't update my drivers as a result and some of my games look terrible now with pulsar on because of the terrible stutter (wuthering waves, arknights:Endfield with x3 frame gen and 120 fps base fps enabled for example).
Ziehesh
Does this monitor have a setting similar to the sharpness on the Zowie? And can i use strobe without vrr?On fixed hz ?
Xl 2546
- LCD_Fanboy
Yeah, it has ULMB 2. The strobing works on fixed refresh rates like 60, 120, 240, and 360Hz, though they might add more in future updates.
As for G-SYNC Pulsar, it does VRR and backlight strobing at the same time between 75Hz and 360Hz. Normal strobing breaks down when your FPS drops, but Pulsar keeps motion looking super clean even if your framerate fluctuates during games.
I grabbed a few comparisons from an online review. Here is the ULMB 2 vs Pulsar vs OLED comparison, followed by a look at Pulsar at 96FPS versus OLED at 360Hz. If you check out the motion tracking shots, you can actually see that Pulsar running at a lower 96FPS ends up looking super close to an OLED at 360Hz:
And here’s the Off vs Pulsar vs ULMB 2 comparison across different refresh rates:
Lastly, here are the ULMB 2 pulse width breakdowns across frequencies:
Hope this helps!
MSIfanboy
Nope it doesn't even a sharpness setting, lol
Pg248qp 540hz, pg27aqn 360hz and this monitor all ulmb2 monitors don't have basic qol setting like a sharpness slider
Ziehesh
This monitor look perfect.i have zowie xl2566k ,and dont know switch to asus or no.I very need sharpness setting in asus menu,but he dont have it ,i can try use sharpness from driver.What about input lag with vrr and pulsar ,better than zowie ?
Xl 2546
daviddave1
nice dude ty. I switched to ulmb2 now for testing purpose. pw 20. is there a consensus for the best setting for high fps shooters?LCD_Fanboy wrote: ↑30 Oct 2026, 11:24Yeah, it has ULMB 2. The strobing works on fixed refresh rates like 60, 120, 240, and 360Hz, though they might add more in future updates.
Hope this helps!
| Now: XG27AQNGV
- LCD_Fanboy
Honestly, just use whatever you prefer from 120 FPS and up. There's no real consensus because a huge chunk of this high FPS obsession is just pure marketing and placebo anyway.daviddave1 wrote: ↑01 Nov 2026, 11:58nice dude ty. I switched to ulmb2 now for testing purpose. pw 20. is there a consensus for the best setting for high fps shooters?
99% of people literally can't notice a 1 to 2 ms difference in monitor latency. We’ve all been sold this lie that if you aren't hitting 720+ FPS you're at a massive disadvantage, when in reality, it's just self-suggestion pushed by brands so you keep buying hardware you don't need.
It actually reminds me of that classic story with Valve and CS back in the day. Players kept spamming forums complaining about bad ping even when servers were fine, so Valve's devs just updated the scoreboard to magically show a few ms less ping than it actually was. The connection didn't change at all, but the placebo effect went crazy. People flooded the forums praising Valve for fixing the servers and swearing the game felt super smooth. Total mind games.
Stepping away from the ultra-high FPS chase to use a G-SYNC Pulsar monitor has zero downsides. You can play anywhere between 75 and 360 FPS and actually get real benefits from it:
- Smart tech beats brute force: Features like G-SYNC Pulsar and ULMB 2 prove that motion clarity comes from smart backlight tech instead of raw power. Since Pulsar works dynamically from 75Hz all the way up to 360Hz, you don't even need a locked framerate. When frame drops or stutters happen, you don't notice them and everything stays smooth, which is something only this tech can achieve. As I showed in the comparison images above, even 96Hz or 120Hz with Pulsar looks just as clear as a 360Hz or 500Hz OLED. Whether you are playing fast competitive games or heavy modern single-player games, a mid-range or budget GPU from a couple of generations ago handles those 96 or 120 FPS easily, with DLSS helping out in newer games.
- Zero OLED headaches and better colors: If you are thinking of switching from old TN panels like the Zowie XL2566K, you can finally forget about washed-out colors and terrible viewing angles. On the flip side, OLED monitors strain your eyes, come with an annoying VRR flicker that will drive you crazy within minutes, and carry constant burn-in anxiety. There is simply nothing else on the market quite like G-SYNC Pulsar, delivering vibrant colors, wide viewing angles, zero burn-in risk, and exceptional motion clarity so you can game for hours in total comfort no matter your refresh rate.
- Resolution: You can enjoy native 1440p on a 27-inch monitor, which is way sharper and more defined than 720p or 1080p on a 24-inch monitor, instead of lowering your in-game settings to absolute garbage just to chase useless FPS.
- Power consumption and wallet savings: You don't need to spend a fortune on top-tier hardware just to hit 720 FPS on 720Hz monitors for zero real-world benefit, all while your PC pulls 500+ watts.
- Real future-proofing: Thanks to G-SYNC Pulsar, you won't need to touch your PC components for years and years. When you look at 720Hz monitors that force you to buy expensive hardware, demanding a ridiculous RTX 5090 just to keep 1% and 0.1% lows stable and prevent stuttering from ruining your game, it makes G-SYNC Pulsar say: "Look what they need just to mimic a fraction of our clarity!" These displays actually surpass them in real-world motion clarity, handle any game genre effortlessly, and let you connect a console to use ULMB 2 without a problem.
- Perfect timing: These monitors launched right when PC hardware pricing got completely out of hand. Instead of blowing thousands of dollars upgrading your GPU, CPU, and RAM just to chase raw frames, you can get incredible visual smoothness for a fraction of that cost just by buying a proper display. NVIDIA actually nailed the timing here.
- kyube
You do realise motion blur is a artifact of latency, right?LCD_Fanboy wrote: ↑01 Nov 2026, 19:3699% of people literally can't notice a 1 to 2 ms difference in monitor latency.
"1 to 2ms difference" when you push 3-digit microsecond pulse on-time, like ULMB2 PW<50 does on, is an absurd difference.
99% is a hyperbole.
That's how sample & hold works. It's how reality works.LCD_Fanboy wrote: ↑01 Nov 2026, 19:36We’ve all been sold this lie that if you aren't hitting 720+ FPS you're at a massive disadvantage, when in reality, it's just self-suggestion pushed by brands so you keep buying hardware you don't need.
You require raw sample rate to be able to emulate analog reality with digital systems.
It's not a lie.
It's more the case that specific slower games don't need high FPS to eliminate motion blur, when discussing purely eye-tracked motion clarity
Phantom array effect & stroboscopic effect are a whole different beast to tackle & require much larger refresh rate values.
Didn't know that, nice findLCD_Fanboy wrote: ↑01 Nov 2026, 19:36It actually reminds me of that classic story with Valve and CS back in the day. Players kept spamming forums complaining about bad ping even when servers were fine, so Valve's devs just updated the scoreboard to magically show a few ms less ping than it actually was. The connection didn't change at all, but the placebo effect went crazy. People flooded the forums praising Valve for fixing the servers and swearing the game felt super smooth. Total mind games.
You are completely ignoring a myriad of issues, which I've outlined many times in this thread, that Pulsar still has.LCD_Fanboy wrote: ↑01 Nov 2026, 19:36Stepping away from the ultra-high FPS chase to use a G-SYNC Pulsar monitor has zero downsides.
I'll even reply to the LLM-like reply down below, because it's funny.
1.) Pulsar (VRR+PWM) doesn't solve macrostuttering. It solves juddering (which happens due to mismatch of refreshTime & frametime) & tearing (spatial artifact, also caused by mismatch between refreshTime & frameTime)LCD_Fanboy wrote: ↑01 Nov 2026, 19:36Smart tech beats brute force: Features like G-SYNC Pulsar and ULMB 2 prove that motion clarity comes from smart backlight tech instead of raw power. Since Pulsar works dynamically from 75Hz all the way up to 360Hz, you don't even need a locked framerate.
Normal VRR also solves this. In fact, fixed refresh rate can also solve juddering & tearing at the same time.
2.) Pulsar, from a eye-tracked motion clarity perspective, can look better than high refresh rate OLED in specific frame rate targets which are <2 ms pulse on-time (or +500Hz effective motion clarity)
1.) VRR Flicker on OLED is a overexaggerated issue and doesn't occur in all 2D/3D titles. For example: Apex, CS2 & other esports games don't have (visible to the naked eye) light flicker on QD-OLED.LCD_Fanboy wrote: ↑01 Nov 2026, 19:36Zero OLED headaches and better colors: If you are thinking of switching from old TN panels like the Zowie XL2566K, you can finally forget about washed-out colors and terrible viewing angles. On the flip side, OLED monitors strain your eyes, come with an annoying VRR flicker that will drive you crazy within minutes, and carry constant burn-in anxiety. There is simply nothing else on the market quite like G-SYNC Pulsar, delivering vibrant colors, wide viewing angles, zero burn-in risk, and exceptional motion clarity so you can game for hours in total comfort no matter your refresh rate.
It's highly dependant on technology (QD-OLED or WOLED)
2.) Burn-in on OLED is also a overexaggerated issue.
3.) Treating Pulsar as a lower ranked eye strain concern than OLED is hillarious, considering you strobe your nervous system with +1800 cd/m² nits for a relatively long duration pulse on-time (due to the curve being mediocre, as they're doing a brightness-first approach)
Frame rate is the single most important visual fidelity upgrade you can do to digital content.LCD_Fanboy wrote: ↑01 Nov 2026, 19:36Resolution:You can enjoy native 1440p on a 27-inch monitor, which is way sharper and more defined than 720p or 1080p on a 24-inch monitor, instead of lowering your in-game settings to absolute garbage just to chase useless FPS.
Calling it "useless" is hyperbole or pure ignorance on how displays work.
1.) Don't play shit games which pull a high amount of power during high FPS gamingLCD_Fanboy wrote: ↑01 Nov 2026, 19:36Power consumption and wallet savings: You don't need to spend a fortune on top-tier hardware just to hit 720 FPS on 720Hz monitors for zero real-world benefit, all while your PC pulls 500+ watts.
There are ~400 / 12k games sample size, which are +500FPS, according to my WIP +500FPS games list, where I've singlehandedly went through each title to see how it performs on modern systems.
2.) Phantom array effect & stroboscopic effect aren't solved without going into 4 digit refresh rate territory.
It's ridiculous to claim 720FPS has "zero real-world benefits"
Just don't play improperly optimized games and you can suddenly enjoy 720FPS @ 720Hz?LCD_Fanboy wrote: ↑01 Nov 2026, 19:36Real future-proofing: Thanks to G-SYNC Pulsar, you won't need to touch your PC components for years and years. When you look at 720Hz monitors that force you to buy expensive hardware, demanding a ridiculous RTX 5090 just to keep 1% and 0.1% lows stable and prevent stuttering from ruining your game, it makes G-SYNC Pulsar say: "Look what they need just to mimic a fraction of our clarity!
Nvidia didn't nail anything.LCD_Fanboy wrote: ↑01 Nov 2026, 19:36Perfect timing:These monitors launched right when PC hardware pricing got completely out of hand. Instead of blowing thousands of dollars upgrading your GPU, CPU, and RAM just to chase raw frames, you can get incredible visual smoothness for a fraction of that cost just by buying a proper display. NVIDIA actually nailed the timing here.
They've released a overpriced QHD@360Hz LCD with a re-iteration of the PG27AQN's panel with nerfed ULMB2 behavior and a mediocre pulse on-time x VRR refresh rate range curve.
The market is simply that bad in regards to VRR+PWM, that Nvidia's implementation actually looks usable compared to competition.
I'm somewhat certain that Titan Army's DYDS 2.0, TCL's MPRT-PLUS or MSI's MPRT-Sync all have the either the same or a better curve than what Pulsar does at 1/2 or 1/3 the price point of Pulsar panels today.
I agree that users blame external factors far too early on, but it highly depends from what target the 1 – 2 ms difference is, what portion of the chain the difference is present in and the cadence of the difference (the assumption is that it's constant, but in real life it almost never is)LCD_Fanboy wrote: ↑01 Nov 2026, 19:36Anyone who claims that 1 or 2 ms ruins games is just repeating what they read online and falling for marketing hype and pure placebo.
They're just convincing themselves a problem exists when it doesn't. Blaming imperceptible latency for playing poorly is just a poor excuse because they refuse to admit they're simply bad at the game, or that their own biological reaction time is the real bottleneck no monitor can fix.
daviddave1
Hey thx for replying! I play Apex Legends at an constant 300 fps. Would u play it on ULMB2 mode or PULSAR?LCD_Fanboy wrote: ↑01 Nov 2026, 19:36Honestly, just use whatever you prefer from 120 FPS and up. There's no real consensus because a huge chunk of this high FPS obsession is just pure marketing and placebo anyway.daviddave1 wrote: ↑01 Nov 2026, 11:58nice dude ty. I switched to ulmb2 now for testing purpose. pw 20. is there a consensus for the best setting for high fps shooters?
Anyone who claims that 1 or 2 ms ruins games is just repeating what they read online and falling for marketing hype and pure placebo. They're just convincing themselves a problem exists when it doesn't. Blaming imperceptible latency for playing poorly is just a poor excuse because they refuse to admit they're simply bad at the game, or that their own biological reaction time is the real bottleneck no monitor can fix.
| Now: XG27AQNGV
