BenQ XL2411P screen overclock
Luci05
Post by Luci05 » 18 Jan 2026, 01:36
Hello, how are you?
I have been reading several topics about monitor overclocking, specifically for the **BenQ Zowie XL2411P**, and I found a lot of different information.
I made some attempts, but they did not work as expected. I managed to set the monitor to **200Hz** using some configurations from this thread:
viewtopic.php?t=8435
The monitor displays an image, but it appears **out of scale or incomplete**, as if the signal is not properly synchronized or as if the cable is disconnected. I used some applications like OORBuster.exe, but it was the same result.
In short, I am here to ask for your help to achieve a **working and stable overclock** on this monitor.
Any guidance, timing suggestions, or step-by-step instructions would be greatly appreciated.
I saw that in some topics the monitor's FW version is mentioned.
Luci05
Re: BenQ XL2411P screen overclock
Post by Luci05 » 18 Jan 2026, 14:30
Well, I ran some tests again at 200Hz, running OorBusterX64.exe, OorBuster.exe, and AntiOutOfRange, everything went fine, but I still keep getting the out of range message, and then the monitor goes black ... I left some photos; if anyone can help in any way, I would be grateful.
Out of rage.jpg (3.62 KiB) Viewed 16635 times
200hz ok with of rage.jpg (5.2 KiB) Viewed 16635 times
Luci05
Post by Luci05 » 19 Jan 2026, 14:04
Maxinator500 Thanks for the message.
I can’t reply to PMs yet due to forum restrictions, so I’m answering here. :(
I already have the V3 firmware, which I downloaded from your Git profile.
However, I have never done this kind of firmware flashing before.
Could you please explain the flashing process step by step (connection, OS, tools, and precautions)?
I want to make sure I do everything correctly and avoid any risk of bricking the monitor.
Thanks in advance.
Maxinator500
Post by Maxinator500 » 20 Jan 2026, 00:41
Luci05 wrote: ↑
19 Jan 2026, 14:04
No problem. Then I'll just send you my contact information.
Luci05 wrote: ↑
19 Jan 2026, 14:04
I will, but not here. All the necessary information is already laying around somewhere here on the forum, so I don't think it's a good idea to make another copypasta which gonna confuse you even more.
darrenfv
Post by darrenfv » 14 Nov 2026, 16:01
Hey Maxinator, i saw you contacted me on pm and offered some help. I really appreciate that but unfortunately i cant answer your pm for some reason. Would you mind sending me another pm with your contact info / discord so i can speak to you, thanks alot!
Post by Chief Blur Buster » 14 Nov 2026, 19:40
darrenfv wrote: ↑
14 Nov 2026, 16:01
New forum members don't get PM priveleges until they have enough posts. The more posts you have, the more priveleges a forum member gains, including private messages.
This moderation queue is because most new members of a typical forum are spammers (And never get approved for their first post), basically posting advertisements as their first messages.
Maxinator500
Post by Maxinator500 » Today, 10:58
darrenfv wrote: ↑
14 Nov 2026, 16:01
It's @bobmanextra on discord.
A year ago, I had a conversation with someone who goes by the name "Luci." I was able to help them, and I hope this experience proves useful to you as well. I’ll forward the messages or try adding you directly to the conversation, so you could extract every bit of info from it.
