Rolling/scanning BFI/strobing (CRT-like)
William Sokol Erhard
Re: Trying to recall what was the monitor released this year with scanline BFI done with FALD
Post by William Sokol Erhard » 06 Jan 2026, 14:43
betonKruglosuTotchno wrote: ↑
06 Jan 2026, 08:49
I just learned that Gsync Pulsar is basically the scanning BFI but also with VRR but I don't have any idea about whether it's certification by Nvidia or something else.
https://www.youtube.com/watch?v=9rnjawJ_QDc&t=699s
Also, I know from a review I posted earlier that P326MV has dumb-ish behaviour in VRR with BFI but IMO that's a trivial problem to solve.
Dyds 2.0 also has intelligent mode and does VRR Rolling Scan
I have no idea if P326MV has 2.0 but if it does then it's half-assed. Really hope they will be doing it better with a firmware update.
Pulsar, for now, appears to be essentially a reference design dictated by Nvidia engineers.
The upside is that Nvidia engineers know what they're doing and I have every confidence it will work pretty much as well as the hardware allows. That doesn't sound like much but compared to what OEMs have been doing, it's a godsend.
The downside is that it's going to be a 27" 1440p360 IPS LCD priced above $600 in 2026.
Post by betonKruglosuTotchno » 07 Jun 2026, 04:44
Interesting video but the translation is not great and I bet they messed up some facts. For example, brightness loss is not due do full screen BFI but due to no headroom in backlight. If Titan Army did not have 1600 nit max brightness they would not be able to maintain brightness with BFI.
Increasing number of beams is fun but I don't think it's possible because of blooming of the backlight zones. You can clearly see in the high FPS video I posted that backlight zones are not well-separated.
Plus I don't know how you are going to transfer the image that quickly, it literally requires 8x the bandwidth if you suggest to use 8 beams.
Either that or some specific GPU-monitor transmission which I never heard of before which is very simple on a computational level but there is clearly no standard for it except maybe splitting a monitor into 8 sub-monitors using DisplayPort + VESA DIsplayID.
Same for meet in the middle beams which you mentioned.
Futuretech wrote: ↑
29 Dec 2025, 20:27
Dyds 1.0 is at 1.5 CRT performance a 15,630Hz; 0.03% higher or 0.05Hz higher than NTSC. Each miniled zone is row-by-row scanning like a CRT it races the beam the moment the pixel is shone the mini-led breaks off at about -64 microseconds. Making it 15 times faster than the sample&hold 1,040Hz ~963mcs Samsung Display.
That's completely incorrect. Backlight driver frequency has nothing to do with motion clarity. There are only two parameters which directly translate into motion clarity: dark ratio and backlight zone separation.
Post by betonKruglosuTotchno » 12 Jul 2026, 07:07
As I understand it TCL has now joined the bandwagon with Tmoc.
Not clear whether it's compatible with VRR or not.
https://www.tcl.com/latin/en/monitors/27p2a-pro
Post by betonKruglosuTotchno » 16 Oct 2026, 05:23
Full list at the moment is:
Titan Army P326MV, P275MV, P276MS Ultra, P276MX Ultra, U255L, X276T and probably many others and many variants
Nvidia Pulsar
TCL 27C2A, 27P2A Pro
Zowie Dyac 3
Re: Rolling/scanning BFI/strobing (CRT-like)
Post by betonKruglosuTotchno » 16 Oct 2026, 05:38
This can't be pursuit photo for the part about BFI, right? Is it just static camera?
https://tweakers.net/reviews/15174/aoc- ... aming.html
Re: Rolling/scanning BFI/strobing (CTR-like)
Post by betonKruglosuTotchno » Yesterday, 07:10
What about backlight zone separation? As I understand it all desktop monitors can only do 2x contrast in checkerboard pattern what means there's a lot of backlight bleeding regardless of zone count. My P326MV Max only does like 1:2000 (basically, 50% of light comes from adjacent zones with BFI) while Macbook miniled can do like 1:50000 with similar IPS panel which means a lot better zone separation.
Will there be anything similar for desktop displays?
https://www.techspot.com/review/2365-ap ... r-display/
kyube
Post by kyube » Yesterday, 18:34
12 Jul 2026, 07:07
As per chimolog's review of MPRT-Plus, it does support VRR capabilities.
I believe DYDS 2.0 is the only technology which incorporates local dimming into the equation as well.
Yesterday, 07:10
This might be a pessimistic way to look at this topic, but I don't expect any MiniLED vendor to do the implementation properly.
Only Apple seems to do it somewhat correctly.
Post by betonKruglosuTotchno » Today, 05:50
Basically, Macbook does it with light guiding plates and this could be done at least in Pulsar since it has zero local dimming anyway.
