I’ve noticed that Valorant forces your resolution to use GPU scaling, regardless of what settings you choose in the NVIDIA Control Panel. When playing on FACEIT, I experience terrible input lag when using display scaling.
I even recently got a temporary ban for manipulating EDID.
At your refresh rate, your UFO should be moving slowly; if it’s flying toward you too quickly, then your system is malfunctioning.
Valorant forces GPU scaling, etc.
Monzy
Re: Valorant forces GPU scaling, etc.
Before you read everything I’ve written below, I want to make it clear that I’m not new to this topic. I’ve been struggling with input lag and that sluggish, muddy feeling in games (both online and offline) for four years now.
My main issue is the feeling that my monitor is running at a lower refresh rate than it actually is, along with textures becoming blurry during sudden movements, which eventually causes me to lose focus.
Based on what I’m about to write, you can draw your own conclusions: either I’ve completely lost my mind and will soon meet God (what’s up, Marv1n?), or maybe there’s actually some truth to what I’m saying. It’s up to you, guys.
First of all, I want to repeat something: I’m not saying that all of you guys here are crazy or anything like that. It’s just that, like many of you, I’ve driven myself into a corner. I can’t seem to find even the slightest solution to this problem — at least not one that lasts longer than a single day.
So, here’s my thought:
What if we looked at input lag from a psychosomatic perspective?
Didn’t get it? Let me use myself as an example.
I wake up, sit down at my PC, launch a DM server, and see that I’m getting 500 FPS, but I just don’t feel the smoothness you’d expect from 240Hz.
What do I do next?
Exactly. I start tweaking absolutely everything on my PC, digging through every setting over and over again, desperately trying to figure out the reason behind this weird, muddy feeling on my screen.
After 2–3 hours, something catches my attention. I think: “THAT’S IT! THIS IS THE SOLUTION! I’ll try this, and maybe it’ll finally go away. Maybe everything will feel right again. Maybe I’ll finally be able to frag like I did back in 2018!”
At that moment, your brain releases dopamine in anticipation of something positive.
It’s similar to gambling addiction. Gamblers don’t necessarily get pleasure from watching the roulette wheel spin. They get excited by the possibility that the next spin might land on 10x and they’ll win a lot of money.
And that’s exactly where I’m going with this.
We’re in a similar situation. We think we’ve finally found a solution, and suddenly we have hope that it’ll actually work.
That combination of anticipation and dopamine makes you consciously start paying attention to how smooth the game feels. Your brain actively looks for confirmation that things have gotten “better.”
And then comes the first game. You drop 25 kills and think: “THAT’S IT! Either I’ve finally fixed the entire problem, or at least I’ve found something that will work for a couple of hours.”
But have you ever stopped to think about how you actually managed to get those 25 kills?
I’ll tell you: confidence.
You made some changes, and you got those 25 kills because you simply stopped doubting your decisions and actions. You entered a state of flow.
On top of that, there’s another factor: reduced anxiety.
When you spend so much time constantly thinking that something is wrong, that your game feels sluggish, that everything feels heavy, etc., your brain ends up dedicating an excessive amount of attention to this perceived “input lag.”
I’m 100% certain that input lag exists. But I’m not so sure about how significant it actually is compared to how much we make it out to be.
What if we’re simply examining every single pixel too closely, desperately searching for a needle in a haystack when there might not even be a needle there in the first place?
I’d really appreciate your thoughts and opinions on this.
I genuinely feel like I’m going insane…
What do I do next?
MontyTheAverage
Didn't you make a post with your fix for lag issues with step by step instructions? What happened did that stop working for you also and you have a new tweak?
Babluga
MontyTheAverage wrote: ↑15 Nov 2026, 06:36Didn't you make a post with your fix for lag issues with step by step instructions? What happened did that stop working for you also and you have a new tweak?
- naporitan
I was mistaken; Valorant only uses display scaling at the monitor's native resolution. For CS2, you need to use display scaling—in the NVIDIA settings, you should set it to "Full-screen" and ensure the checkbox is left unchecked.MontyTheAverage wrote: ↑15 Nov 2026, 06:36Didn't you make a post with your fix for lag issues with step by step instructions? What happened did that stop working for you also and you have a new tweak?
