Oh interesting. Then in my case reflex would be enabled. Low latency mode is turned off. It is curious though because in RTSS it says my optimal VRR cap is at 228 FPS, in contrast to reflex which configures it to be 225 for my monitor's refresh rate of 240 Hz. RealNC, you have the same XG27AQDMG monitor as me correct? What VRR frame cap does RTSS report to you? I guess reflex and RTSS calculate with different formulas which would explain the discrepancy.
ExplodinFistz
- Screenshot 2026-06-12 091036.png (65.67 KiB) Viewed 4111 times
- RealNC
Yeah. Reflex uses this formula:ExplodinFistz wrote: ↑12 Jun 2026, 09:16Oh interesting. Then in my case reflex would be enabled. Low latency mode is turned off. It is curious though because in RTSS it says my optimal VRR cap is at 228 FPS, in contrast to reflex which configures it to be 225 for my monitor's refresh rate of 240 Hz. RealNC, you have the same XG27AQDMG monitor as me correct? What VRR frame cap does RTSS report to you? I guess reflex and RTSS calculate with different formulas which would explain the discrepancy.
Hz * 3600 / (Hz + 3600)
RTSS uses something else.
knypol
What gives best effect in smoothness: gsync + vsync (NVCP) or gsync + rtss fps cap?
- jorimt
Technically, purely where "smoothness" is concerned, G-SYNC + NVCP V-SYNC + RTSS FPS limit.
G-SYNC + RTSS FPS limt without V-SYNC can still tear, and visible tearing artifacts (however slight or infrequent) can = less "smooth."
