MSIfanboy
Post by MSIfanboy » 14 Nov 2026, 00:18
Ziehesh wrote: ↑
09 Nov 2026, 00:16
Zee wrote: ↑
07 Nov 2026, 07:51
I haven't used a zowie monitor for now, but I had a ULMB2 one before and switched to the Asus pulsar from a 1440p OLED 480 Hz.
While input lag should be higher on the pulsar, I don't perceive it.
Objectively it should be higher, even than your current zowie. If you objectively feel it, it don't know. I, for sure, don't. And I play cs2 and ow2 on a high rank.
I can personally recommend it, I will use my OLED as a second monitor from now on.
I’d like to get an OLED display, but I sometimes play World of Warcraft, which involves a lot of static images. I’m afraid the OLED panel won’t last long in such a scenario.
Does anyone have access to Rtings? Could you please send the input lag for the XQ2566X monitor?
The Empyrean
Post by The Empyrean » 17 Nov 2026, 11:46
Do we know whether the 60hz, 120hz, 240hz and 360hz use rolling scan or global flash for ULMB2 modes?
RynoW
Post by RynoW » 17 Nov 2026, 13:48
Looking forward to the final patch, and I hope we get the NVAPP selection per game for G-Sync/Pulsar/ULMB2/Off. Manually turning off G-Sync and setting the display refresh rate to 60Hz every time I want to play a fixed-refresh 60Hz game is getting to be a pain.
liquidshadowfox
Post by liquidshadowfox » 20 Nov 2026, 21:40
Has anyone checked out the github project for NvidiaGsyncTweaks? There seems to be some settings in there to adjust some pulsar specific settings that may or may not be useful...
paradox404
Post by paradox404 » Yesterday, 14:32
Hi, is this the cabble needed for updating the firmware?
https://www.amazon.de/-/en/Amazon-Basic ... r=1-3&th=1
tsarri
Post by tsarri » Yesterday, 15:01
liquidshadowfox wrote: ↑
20 Nov 2026, 21:40
Let us know if you check it out
y0y0
Post by y0y0 » Yesterday, 18:56
paradox404 wrote: ↑
Yesterday, 14:32
yes, should be fine
kyube
Post by kyube » Yesterday, 18:59
An update in regards to GSYNC Pulsar with a reduced duty cycle curve:
drG-SYNC wrote: “Working on it. Getting half duty cycle Pulsar working flicker free is turning out to be very hard. It's like I stated earlier: Making Pulsar flicker free is extremely complex, and doing it for arbitrary pulse widths is too complex. Even adding one other pulse width is harder than I expected.”
