I'm giving up on mouse floaty
kwahjs
Re: I'm giving up on mouse floaty
Post by kwahjs » 23 Nov 2026, 20:06
By the way, when my mouse starts lagging, the game’s smoothness and the sound through my headphones get really bad—I just had to mention that.
No, I live in the city center, but my next-door neighbor’s computer has no problems at all. When I took my PC over there, everything was the same as before; it only worked properly for about an hour, and then the same problem started again. After that, I just connected my computer case to his equipment, but nothing changed—the problem persisted. Immediately afterward, I connected my neighbor’s computer case to my equipment, and there were no issues at all. So, I’m leaning toward the idea that the computer case has sustained permanent damage due to poor electrical connections. That’s why it’s malfunctioning no matter where we take it.
Yes, I sold all my equipment—I’m going to buy everything new, even my computer desk and chair :)
Right now, I’m just waiting.
As I said, your computer sustains permanent damage in the house where this problem started, and you experience the same issues wherever you go—it might work fine for the first few hours or even a few days, but then the problem comes back.
Don’t even think about getting a new system while you’re still in the same house—you’ll just go through the same thing again. The problem isn’t caused by AMD or Intel, so don’t waste your money.
Before selling it, I brought my PC to my workplace one last time—I work in an office—and connected it to the office’s 60Hz monitor. For the first few hours, it ran better than on my 600Hz monitor, but then, little by little, the mouse lag set in, the sound quality deteriorated, and the smoothness completely disappeared. I took the PC apart piece by piece and sold everything.
I’ll let you know when I move. My PC is ready, but I’ll never connect it to this house.
I apologize for my poor English
Apexer15
Post by Apexer15 » 24 Nov 2026, 10:49
I'm not sure if its a permanent damage to the PC but thank you for sharing your story
spkii
Post by spkii » 24 Nov 2026, 11:28
kwahjs wrote: ↑
23 Nov 2026, 20:06
So, the Theory is that computer is damaged but all parts of it? Change monitor, mouse, keyboard, etc?
ablemor
Post by ablemor » 24 Nov 2026, 12:29
Forget about a part getting damaged and causing lag there’s no such thing, and there never was. It’s not hardware-dependent; the electrical grid is weak. You can bring anything there and it’ll still run poorly.
spkii
Post by spkii » 24 Nov 2026, 13:58
ablemor wrote: ↑
24 Nov 2026, 12:29
Then trying with an Eco Flow Delta Pro 3 (6-7 hours battery dependant) should work?
kwahjs
Re: Mouse floaty'den vazgeçiyorum
Post by kwahjs » Today, 00:59
ablemor wrote: ↑
24 Nov 2026, 12:29
So, is the electrical supply bad in every single house where I’ve taken and tested the setup? I took it to my uncle’s place—no issues on my cousin’s computer—but 3–4 hours later, the same problem reappeared. I’ve tested it at my grandfather’s detached house, at friends’ homes, at my neighbor’s place, and at my brother’s house; I’ve even tested it at the homes of a friend who has moved seven times. These locations are all 15–20 km apart. There has to be a logical explanation. Could it be that high EMI (electromagnetic interference) in the house where the issue begins is causing permanent damage to the PSU or motherboard components? Or is the problem actually originating from us—could our own bodies be introducing the latency while we hold the mouse? This is exactly where the problem becomes a vicious cycle; no one knows what’s actually happening. If we think logically, we need to stop taking the claim that "it won't cause permanent damage" for granted—we have to consider every single possibility.
kwahjs
Post by kwahjs » Today, 01:04
spkii wrote: ↑
24 Nov 2026, 11:28
kwahjs wrote: ↑
23 Nov 2026, 20:06
I don’t think the peripherals would sustain permanent damage, but just to be on the safe side and avoid any risk, I sold them to someone I know—who confirmed there were no issues at all. I also tested my equipment at internet cafés and on other computers, and there were no problems, but I decided to sell them anyway.
