Oh interesting. Then in my case reflex would be enabled. Low latency mode is turned off. It is curious though because in RTSS it says my optimal VRR cap is at 228 FPS, in contrast to reflex which configures it to be 225 for my monitor's refresh rate of 240 Hz. RealNC, you have the same XG27AQDMG monitor as me correct? What VRR frame cap does RTSS report to you? I guess reflex and RTSS calculate with different formulas which would explain the discrepancy.
ExplodinFistz
- Screenshot 2026-06-12 091036.png (65.67 KiB) Viewed 4305 times
- RealNC
Yeah. Reflex uses this formula:ExplodinFistz wrote: ↑12 Jun 2026, 09:16Oh interesting. Then in my case reflex would be enabled. Low latency mode is turned off. It is curious though because in RTSS it says my optimal VRR cap is at 228 FPS, in contrast to reflex which configures it to be 225 for my monitor's refresh rate of 240 Hz. RealNC, you have the same XG27AQDMG monitor as me correct? What VRR frame cap does RTSS report to you? I guess reflex and RTSS calculate with different formulas which would explain the discrepancy.
Hz * 3600 / (Hz + 3600)
RTSS uses something else.
knypol
What gives best effect in smoothness: gsync + vsync (NVCP) or gsync + rtss fps cap?
- jorimt
Technically, purely where "smoothness" is concerned, G-SYNC + NVCP V-SYNC + RTSS FPS limit.
G-SYNC + RTSS FPS limit without V-SYNC can still tear, and visible tearing artifacts (however slight or infrequent) can = less "smooth."
Displays: ASUS P27UCWM, LG 48C4 OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboard: Wooting 60HE v2 Mouse: Logitech G Pro X2 SUPERSTRIKE Sound: Creative Sound Blaster Katana V2 VR: Beyond 2, Quest 3, Reverb G2, Index Consoles: N64, Analogue 3D, Dreamcast, PS2, PS3, PS5 Pro, Switch 2, Wii, Xbox, Xbox 360, Analogue Pocket + Dock Scaler: RetroTINK 4k
knypol
I've had an Asus Pulsar monitor for two months and I've noticed that when the frame rate in games fluctuates between 170-200, even with Gsync enabled, the image isn't smooth. It's not tearing, but the image is somewhat unstable. The image only becomes perfect when the frame rate is super stable (225 at 240Hz with Reflex On and Vsync On). This somewhat undermines the Gsync concept, as it's so noticeable to me when the frame rate spikes. Unless I'm just hypersensitive to it. For fps below 240, I use 240Hz mode because at 360Hz, the image becomes terrible, almost sample-and-hold blurry. Unless I have something misconfigured in my system, I'm not sure what - I use NVCP Vsync On + Gsync, and in-game Reflex On.
- jorimt
If you're referring to uneven frame-pacing and/or micro-stutter, VRR can't and won't fix it, and will reflect it as-is, just without tearing (with G-SYNC on + V-SYNC on).knypol wrote: ↑Today, 09:08I've noticed that when the frame rate in games fluctuates between 170-200, even with Gsync enabled, the image isn't smooth. It's not tearing, but the image is somewhat unstable. The image only becomes perfect when the frame rate is super stable (225 at 240Hz with Reflex On and Vsync On).
As to the remainder, I assume you're using VRR + strobing? If so, I've never tested it directly, and it is very new (up until Pulsar, VRR and strobing could never be used in conjunction), so there could still be certain Pulsar ranges that don't have as solid of a VRR/strobing synchronization, especially where frametime performance may be less stable.
You could try normal G-SYNC mode sans Pulsar to confirm whether it differs in your problem scenario.
