100Hz
Intensity = 01
Area = 50
Single Strobe = OFF
That probably explains why the suggested Tweaks didn't work on mine...Falkentyne wrote:So they reversed it, apparently.
1 intensity =low effect of blur reduction=bright screen (high persistence in ms, e.g. 2.5ms)
25 intensity (max)=dark screen=lowest persistence in ms=highest effect of blur reduction, e.g. 0.5ms
But now there are only 25 values instead of 30...
Wonder what the actual persistence values are on this thing.
Anyone want to send one over to Masterotaku? he's going to have a field day with this thing...
He took the photos without following the UFOs with the camera. Overdrive artifacts look a lot fainter than in real life. I remember that when Chief posted a photo of his XL2720Z, it was a still photo and it almost didn't show artifacts (only crosstalk), and that made me think the XL2411Z wouldn't have overdrive artifacts. And you see that you and me have themFalkentyne wrote: 1) ghosting is much lower on yours than on the 2720Z. I don't know if that's because of blur reduction 2.0 or because I have a 27" panel.
That's not the case, shutter at 1/100 for 100Hz. I did compare to my shot and the screen after taken the photo on my DSLR and it looks the same as I see with my naked eyes.masterotaku wrote:I had a post prepared but both of you were faster than me.
Good to know that intensity is reversed.
He took the photos without following the UFOs with the camera. Overdrive artifacts look a lot fainter than in real life. I remember that when Chief posted a photo of his XL2720Z, it was a still photo and it almost didn't show artifacts (only crosstalk), and that made me think the XL2411Z wouldn't have overdrive artifacts. And you see that you and me have themFalkentyne wrote: 1) ghosting is much lower on yours than on the 2720Z. I don't know if that's because of blur reduction 2.0 or because I have a 27" panel..
