I was testing a old Panasonic HDTV against a 120hz monitor I have with human benchmark
http://www.humanbenchmark.com/tests/reactiontime/
And I averaged about 111 ms faster on the 120hz monitor
But when I tested with timer here:
http://tft.vanity.dk/
It measured the difference at only 50 ms.
Any theories on what's going on here?
Testing input lag via timer vs human benchmark
- sharknice
Re: Testing input lag via timer vs human benchmark
dunebeetle wrote:I was testing a old Panasonic HDTV against a 120hz monitor I have with human benchmark
The tests themselves have input lag. So you can't really compare between different tests.
flood
back when human benchmark was flash i got more or less the same result on it as i did on a custom program i made myself to do the same thing at >1000fps
anyway using timers is really unreliable for measuring input lag
also if you have aero on, 120hz has less vsync lag than 60hz
