Hey!
Question is same as my name of thread. If I uninstall Blur Busters Strobe Utility will settings backs to default values?
If not then please give me basic settings for xl2411z.
Best regards,
Kepasapl
Strobe Utility. If I uninstall will it back to bacis sets?
Re: Strobe Utility. If I uninstall will it back to bacis set
I don't think they will reset. The tool only helps you do the same as you would from the BenQ service (hidden) menu.
Some good settings are ~1.0ms persistence - 0 crosstalk (all the way to the left). That would reduce brightness a lot so you should put 100 for brightness and also use the VT tweak if you want (through nvidia cp or toastyx).
Right now I have got 4.0ms and down bar max for the left. What do you mean "TV tweak"? I will use my XL2411Z for normal daily work and for cs:go. So 1.0ms in my opinions it's to dark.
Here's the VT tweak, you can get more out of the monitor by using it:
http://forums.blurbusters.com/viewtopic.php?f=13&t=560
Ok I will look at it. Tell me one thing, please. Will it change something (help) if I play on the lower resolution that 1920x1080? I asked you because I usually play cs:go on 800x600. I get used to it and I like it.
EDIT:
Which settings are "default"?
EDIT:
