That's interesting, I don't remember anyone reporting similar issues with any of those games. What are your system specs?MxOAgentJohnson wrote:Right now i'm trying 3 games out, if the fps fluctuates on them the mouse stutters but if i use a gamepad it is silky smooth if the fps jumps about
the games tested Tomb Raider, Batman Arkham Origins and Ethan Carter.
My mouse is a Razer Abyssus at 1000hz polling rate, infact if i turn the polling rate down it stutters even more.
If the fps is locked to 60 or 120, always the mouse is fine.
This is getting weird.
G-Sync game compatibility - Post your test results here
- nimbulan
Re: G-Sync game compatibility - Post your test results here
MxOAgentJohnson
CPU: i7 4790k Devils Canyon @ 4GHZ - GPU: MSi 970 4GB - RAM: 8GB Samsung Green - HARDRIVE: x1 840 SSD, x1 2TB WD, x1 250GB Maxtor - Motherboard - Asus - Cooler Akasa Venom
Alexious
What kind of GSYNC monitor do you have?MxOAgentJohnson wrote:CPU: i7 4790k Devils Canyon @ 4GHZ - GPU: MSi 970 4GB - RAM: 8GB Samsung Green - HARDRIVE: x1 840 SSD, x1 2TB WD, x1 250GB Maxtor - Motherboard - Asus - Cooler Akasa Venom
MxOAgentJohnson
Wont make a difference but acer 27" 1920x1080Alexious wrote:What kind of GSYNC monitor do you have?MxOAgentJohnson wrote:CPU: i7 4790k Devils Canyon @ 4GHZ - GPU: MSi 970 4GB - RAM: 8GB Samsung Green - HARDRIVE: x1 840 SSD, x1 2TB WD, x1 250GB Maxtor - Motherboard - Asus - Cooler Akasa Venom
- sharknice
It sounds like your mouse settings are bad. Are you using mouse smoothing, acceleration, or anything else like that? I know Razer has options to use non-native mouse DPI which could also be messing it up.MxOAgentJohnson wrote: Right now i'm trying 3 games out, if the fps fluctuates on them the mouse stutters but if i use a gamepad it is silky smooth if the fps jumps about
MxOAgentJohnson
Nothing to do with mouse, happens on multiple mouses, multiple pcs and doesnt happen with gsync off in these games, its the games and gsync itself.sharknice wrote:It sounds like your mouse settings are bad. Are you using mouse smoothing, acceleration, or anything else like that? I know Razer has options to use non-native mouse DPI which could also be messing it up.MxOAgentJohnson wrote: Right now i'm trying 3 games out, if the fps fluctuates on them the mouse stutters but if i use a gamepad it is silky smooth if the fps jumps about
- sharknice
I've never had any of those problems in Tomb Raider. I don't have the other games. It sounds very similar to the effects of using poorly programed mouse smoothing or acceleration that is dependent on frame rate.MxOAgentJohnson wrote:Nothing to do with mouse, happens on multiple mouses, multiple pcs and doesnt happen with gsync off in these games, its the games and gsync itself.sharknice wrote:It sounds like your mouse settings are bad. Are you using mouse smoothing, acceleration, or anything else like that? I know Razer has options to use non-native mouse DPI which could also be messing it up.MxOAgentJohnson wrote: Right now i'm trying 3 games out, if the fps fluctuates on them the mouse stutters but if i use a gamepad it is silky smooth if the fps jumps about
MxOAgentJohnson
Its not every game that this happens, some games are amazing regardless of framerate, others just get an odd hitchy camera when the fps is in the 72-89 fps zone for some reason. Splinter Cell, Tomb Raider, A bit of Hitman Absoloution, Hard Reset.sharknice wrote:I've never had any of those problems in Tomb Raider. I don't have the other games. It sounds very similar to the effects of using poorly programed mouse smoothing or acceleration that is dependent on frame rate.MxOAgentJohnson wrote:Nothing to do with mouse, happens on multiple mouses, multiple pcs and doesnt happen with gsync off in these games, its the games and gsync itself.sharknice wrote:It sounds like your mouse settings are bad. Are you using mouse smoothing, acceleration, or anything else like that? I know Razer has options to use non-native mouse DPI which could also be messing it up.MxOAgentJohnson wrote: Right now i'm trying 3 games out, if the fps fluctuates on them the mouse stutters but if i use a gamepad it is silky smooth if the fps jumps about
However Sleeping Dogs, Resident Evil 6, F3AR are all fine regardless of the fps, so no idefa.
- sharknice
I also have splinter cell and have never had problems with that one either.
- nimbulan
I know that Hard Reset's engine (also used in Shadow Warrior) is known to not run smoothly. Tomb Raider has been one of the smoothest running games I have ever played on my system both with my old GTX 760 and my new GTX 970.
